2 Pages12>
jschwein
#1 Posted : Sunday, March 22, 2009 11:02:44 AM(UTC)
jschwein
the washer will work fine all but spin the washer will drain and if you lift the lid will spin.at other times it works ok.based on other posts we have replaced the motor coupler,clutch,timer,door switch,motor control one part at a time and still have the problem any ideas? my wife is starting to think i can't fix the thing is about to call a repairman.
#2 Posted : Monday, March 23, 2009 12:55:33 PM(UTC)
Which part did you call "motor control"? Would it spin with your help (manually move the inner tub)?
Here are the break down diagrams and Replacement parts for WHIRLPOOL GSL9365EQ1 | AppliancePartsPros.com
jschwein
#3 Posted : Monday, March 23, 2009 7:10:34 PM(UTC)
jschwein
the part i'm calling motor control is part # 20 in the brake,clutch,gearcase motor and pump parts list and it will not start if you try to spin the drum
#4 Posted : Tuesday, March 24, 2009 9:39:47 AM(UTC)
Check the drive block and the spin tube as described in one of our previous posts: http://forum.appliancepartspros...ir/373-not-spinning.html
jschwein
#5 Posted : Thursday, March 26, 2009 9:28:37 AM(UTC)
jschwein
checked the block didn't find anything broken,the drum is very hard to turn feels as if it is locked in place.took out the transmission asmy and it is still hard to turn. should we replace the block anyway? thanks for your help.
#6 Posted : Thursday, March 26, 2009 10:06:04 AM(UTC)
Do not rush with the parts without proper diagnosis. The next step I would recommend is check the brakes as described here: http://forum.appliancepartspros...-washer-brake-shoes.html
jschwein
#7 Posted : Friday, March 27, 2009 7:48:56 AM(UTC)
jschwein
everything looks and feels ok did as the post said put washer back together washer drum moves smooth and will spin if you lift and close the lid or if you wait a little while the motor will stop and start again and will spin. the wife had me call the local repair guy on the phone who said it is the transmision he replaces 1 about every 2-3 months i can't believe that this is the problem.thanks for your input
#8 Posted : Friday, March 27, 2009 12:26:34 PM(UTC)
Originally Posted by: jschwein Go to Quoted Post
...will spin if you lift and close the lid or if you wait a little while the motor will stop and start again and will spin
Due to your washer has a neutral drain transmission, it should stop for a few seconds during the drain to engage the spin. This stop interval operates by the timer and has nothing to do with the transmission.
jschwein
#9 Posted : Friday, March 27, 2009 8:32:53 PM(UTC)
jschwein
the motor stops then restarts but spin may not start if you let it sit it may start or may go to the rinse and after that may or may not spin but every time i have lifted the lid and it spins it go to rinse and will spin. thanks for your input
#10 Posted : Saturday, March 28, 2009 3:48:35 PM(UTC)
The washer still does not work properly after you replaced most of parts and checked the rest. I'm really stumped. Maybe somebody else on the forum van help you better.
Guest (5)
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
GE washer will not spin (Washer Repair)
by MS104 5/10/2016 4:34:48 PM(UTC)
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 8/26/2015 7:56:10 PM(UTC)
by howard6168 7/5/2015 5:47:41 AM(UTC)
Kenmore 800 Washer will not spin (Washer Repair)
by AnneKenzie 6/18/2015 12:01:29 PM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
washer will not spin out (Washer Repair)
by kdwarren16yrs 12/27/2014 6:42:50 AM(UTC)
ge profile washer will not spin (Washer Repair)
by ron dog 11/29/2014 5:27:31 PM(UTC)
Washer will not spin/drain (work) (Washer Repair)
by dupdc 8/20/2014 2:50:08 AM(UTC)
Whirlpool Cabrio Washer Will Not Spin (Washer Repair)
by pacdave 5/7/2014 6:40:52 PM(UTC)
2 Pages12>
