4 Pages«<234
chilidog
#31 Posted : Tuesday, May 22, 2012 5:13:55 PM(UTC)
chilidog
The burner is in transit now. I know how hard it is to diagnose stuff without actually being the technician looking at the appliance. I appreciate your help, on my own I would probably just throw the $2000 oven out.
Thanks alot for your help, Ron
#32 Posted : Tuesday, May 22, 2012 5:24:00 PM(UTC)
You are welcome Ron. Hopefully it will fix it. Keep us posted.
chilidog
#33 Posted : Saturday, May 26, 2012 4:44:19 PM(UTC)
chilidog
I put in the new burner, the same problem. It lights once, heats for afew minutes, goes off, tries 4 sparks to relight and it doesnt light. After a few minutes, it tries to relight,4 sparks, sometimes it lights, more often it doesn't. This is the same with the all the new parts, or the old parts.
Right now, using the old burner, I drilled 2 small holes closer to the spark ignighter(sensor). I have fined tuned the sensor , bending it to a spot where it lights on the first attempt. I bent it closer and in a postion that gets more flame. It so far has acheived the correct temps I have told it. This is also with all the original parts.
I think most of my ovens problem is altitude. The oven has worked fine for years, I have no idea why it started this not staying lit problem, but as it is set now, after several test runs, it is doing good.
I will keep you posted, thanks for all your help Gene, I appeciate it.
Ron
#34 Posted : Tuesday, May 29, 2012 2:14:48 PM(UTC)
You are welcome Ron. BTW, I did recommend to replace the burner assembly because I felt the problem was with the flame sensing.
Guest (13)
Whirlpool oven shuts off overnight (Oven Repair (including Ranges and Cooktops))
by Guest 4/15/2021 3:53:14 PM(UTC)
Oven shuts off by itslf (Oven Repair (including Ranges and Cooktops))
by kdsagun 4/15/2018 5:55:28 PM(UTC)
Oven shuts off after heating up (Oven Repair (including Ranges and Cooktops))
by ravellar 4/24/2017 12:10:21 PM(UTC)
Whirlpool oven shuts off baking/broiling (Oven Repair (including Ranges and Cooktops))
by bremen242 2/13/2017 4:12:13 PM(UTC)
Whirlpool Gold oven shuts off when temp changed (Oven Repair (including Ranges and Cooktops))
by texicus 9/24/2015 9:30:38 AM(UTC)
Panasonic oven shuts off NN-SA651S (Microwave Repair)
by ladybridgeport 4/23/2014 10:49:07 AM(UTC)
Oven shuts off by itself (Oven Repair (including Ranges and Cooktops))
by bobtam 5/16/2013 3:40:22 PM(UTC)
oven shuts off after 45 min (Oven Repair (including Ranges and Cooktops))
by Karl Lauther 4/22/2013 2:49:55 PM(UTC)
kenmore ultra bake oven shuts off (Oven Repair (including Ranges and Cooktops))
by urbanrover 3/13/2013 12:47:40 PM(UTC)
Oven shuts off while cooking, sometimes trouble starting (Oven Repair (including Ranges and Cooktops))
by mrs9693nj 2/15/2013 1:31:41 PM(UTC)
JENN-AIR oven shuts off after a few minutes of heating (Oven Repair (including Ranges and Cooktops))
by toolrules 2/10/2013 7:45:46 PM(UTC)
After pre heat oven shuts off (Oven Repair (including Ranges and Cooktops))
by rider136 9/24/2012 3:37:31 PM(UTC)
Jenn-air oven shuts off (Oven Repair (including Ranges and Cooktops))
by Wardenmotorsports 9/18/2012 4:21:59 PM(UTC)
Oven shuts off (Oven Repair (including Ranges and Cooktops))
by richwest41 8/22/2012 4:10:05 PM(UTC)
Oven shuts off within ten minutes (Oven Repair (including Ranges and Cooktops))
by TMeck 8/22/2012 2:00:23 PM(UTC)
4 Pages«<234
