4 Pages<1234>
#11 Posted : Wednesday, May 16, 2012 3:41:04 PM(UTC)
I'm afraid I did not get it clear: which control board is installed now?
chilidog
#12 Posted : Wednesday, May 16, 2012 5:13:03 PM(UTC)
chilidog
The original is in now. Same thing on problem, broiler works good, oven still does the same. It ran for about one minute, gas went off, relit once, went off again, wouldn't try to restart. Oven light bulb only turns on with push button.
#13 Posted : Wednesday, May 16, 2012 5:42:08 PM(UTC)
In such situation I would replace the spark module.
- The spark module Part number: W10331686
chilidog
#14 Posted : Wednesday, May 16, 2012 5:48:46 PM(UTC)
chilidog
Is the burner suposed to cycle on and off before it gets to temp setting on panel?
#15 Posted : Wednesday, May 16, 2012 6:07:51 PM(UTC)
Normally not. If it does it, you may want to order the new burner as well.
chilidog
#16 Posted : Wednesday, May 16, 2012 6:40:00 PM(UTC)
chilidog
Okay. I will order both. Will update after installation.
Thanks,Ron
chilidog
#17 Posted : Thursday, May 17, 2012 7:24:24 AM(UTC)
chilidog
Are there any readings to go by for the thermostat?
#18 Posted : Thursday, May 17, 2012 5:55:17 PM(UTC)
Which thermostat?
chilidog
#19 Posted : Thursday, May 17, 2012 6:28:39 PM(UTC)
chilidog
The thermostat in the front under control panel. Not the thermal in rear.
#20 Posted : Monday, May 21, 2012 6:05:33 PM(UTC)
Sorry for the delay.
Can you refer to the diagrams please?
Whirlpool oven shuts off overnight (Oven Repair (including Ranges and Cooktops))
by Guest 4/15/2021 3:53:14 PM(UTC)
Oven shuts off by itslf (Oven Repair (including Ranges and Cooktops))
by kdsagun 4/15/2018 5:55:28 PM(UTC)
Oven shuts off after heating up (Oven Repair (including Ranges and Cooktops))
by ravellar 4/24/2017 12:10:21 PM(UTC)
Whirlpool oven shuts off baking/broiling (Oven Repair (including Ranges and Cooktops))
by bremen242 2/13/2017 4:12:13 PM(UTC)
Whirlpool Gold oven shuts off when temp changed (Oven Repair (including Ranges and Cooktops))
by texicus 9/24/2015 9:30:38 AM(UTC)
Panasonic oven shuts off NN-SA651S (Microwave Repair)
by ladybridgeport 4/23/2014 10:49:07 AM(UTC)
Oven shuts off by itself (Oven Repair (including Ranges and Cooktops))
by bobtam 5/16/2013 3:40:22 PM(UTC)
oven shuts off after 45 min (Oven Repair (including Ranges and Cooktops))
by Karl Lauther 4/22/2013 2:49:55 PM(UTC)
kenmore ultra bake oven shuts off (Oven Repair (including Ranges and Cooktops))
by urbanrover 3/13/2013 12:47:40 PM(UTC)
Oven shuts off while cooking, sometimes trouble starting (Oven Repair (including Ranges and Cooktops))
by mrs9693nj 2/15/2013 1:31:41 PM(UTC)
JENN-AIR oven shuts off after a few minutes of heating (Oven Repair (including Ranges and Cooktops))
by toolrules 2/10/2013 7:45:46 PM(UTC)
After pre heat oven shuts off (Oven Repair (including Ranges and Cooktops))
by rider136 9/24/2012 3:37:31 PM(UTC)
Jenn-air oven shuts off (Oven Repair (including Ranges and Cooktops))
by Wardenmotorsports 9/18/2012 4:21:59 PM(UTC)
Oven shuts off (Oven Repair (including Ranges and Cooktops))
by richwest41 8/22/2012 4:10:05 PM(UTC)
Oven shuts off within ten minutes (Oven Repair (including Ranges and Cooktops))
by TMeck 8/22/2012 2:00:23 PM(UTC)
4 Pages<1234>
