This is Kenmore model number and I can not find any documentations for their products. Besides the TCO there suppose to be a regular in line fuse. Did you check it?
Fuses good. I have power and to the first board. After that no power makes me think main board. For the costs and the gamble not knowing if that's the exact issue might just replace.
been reading along with this post my oven just died it's blank sca1001hss 03 checked for 120 volts to the cn1 terminals on the main board no voltage does this mean the board is bad? theres 120v to the top board fuse
Originally Posted by: darylnj  ...checked for 120 volts to the cn1 terminals on the main board... How did you do it? Gene.
found a burnt plug on the top feeding the sensor,on the left side this oven gets very hot
theres 3 wires 2 red 1 black that go to the tco #1430 with a white plastic connector the plastic connector melted
You have to replace the TCO and fix the wires. The two red wires should go to one terminal while the black goes to the second terminal. - The cavity TCO Part number: WB21X10046
