8 Pages«<5678>
ChicagoMicro
#61 Posted : Tuesday, February 7, 2012 5:12:09 PM(UTC)
ChicagoMicro
Model # 36363693302
ChicagoMicro
#62 Posted : Tuesday, February 7, 2012 5:19:26 PM(UTC)
ChicagoMicro
36363693302
#63 Posted : Tuesday, February 7, 2012 6:46:21 PM(UTC)
This is Kenmore model number and I can not find any documentations for their products. Besides the TCO there suppose to be a regular in line fuse. Did you check it?
ChicagoMicro
#64 Posted : Tuesday, February 7, 2012 6:58:20 PM(UTC)
ChicagoMicro
Fuses good. I have power and to the first board. After that no power makes me think main board. For the costs and the gamble not knowing if that's the exact issue might just replace.
darylnj
#65 Posted : Tuesday, May 8, 2012 7:18:00 AM(UTC)
darylnj
been reading along with this post my oven just died it's blank sca1001hss 03 checked for 120 volts to the cn1 terminals on the main board no voltage does this mean the board is bad? theres 120v to the top board fuse
#66 Posted : Wednesday, May 9, 2012 3:03:48 PM(UTC)
Originally Posted by: darylnj Go to Quoted Post
...checked for 120 volts to the cn1 terminals on the main board...
How did you do it?
darylnj
#67 Posted : Thursday, May 10, 2012 2:58:06 AM(UTC)
darylnj
found a burnt plug on the top feeding the sensor,on the left side
this oven gets very hot
#68 Posted : Monday, May 14, 2012 1:46:18 PM(UTC)
Can you refer to the diagrams reference numbers please?
Here are the breakdown diagrams and Replacement parts for General Electric SCA1001HSS03 Counter top microwave | AppliancePartsPros.com
darylnj
#69 Posted : Monday, May 14, 2012 1:59:17 PM(UTC)
darylnj
theres 3 wires 2 red 1 black that go to the tco #1430 with a white plastic connector the plastic connector melted
#70 Posted : Monday, May 14, 2012 4:20:13 PM(UTC)
You have to replace the TCO and fix the wires. The two red wires should go to one terminal while the black goes to the second terminal.
- The cavity TCO Part number: WB21X10046
8 Pages«<5678>
