7 Pages«<4567>
#51 Posted : Wednesday, May 2, 2012 12:38:57 AM(UTC)
Good,no refrigeration problems, points to a bad board I mentioned, unless you want to keep the box fan on it permanently.
chrison600
#52 Posted : Thursday, May 10, 2012 12:20:42 PM(UTC)
chrison600
Ok. I replaced the second control board. Condenser fan now seems to be operating normally (every time I check, it's running).
However, occasionally the compressor will get more noisy (same noise, just louder) and the freezer temp will elevate. It's like clockwork: compressor noise increases, check the temps, freezer is elevating, divider gets hot, eventually temps go back to normal.
Ideas?
Chris
#53 Posted : Thursday, May 10, 2012 3:20:38 PM(UTC)
If you have a meter, I would start by monitoring the voltage to the fridg from the wall outlet, seems like you have a power problem.
chrison600
#54 Posted : Thursday, May 10, 2012 3:22:32 PM(UTC)
chrison600
I have a basic multi meter, but nothing that would record activity. Do I need a long-term record, or just to monitor for a few minutes? What am I looking for?
Chris
chrison600
#55 Posted : Friday, May 11, 2012 6:39:48 AM(UTC)
chrison600
The inverter box has a discolored spot on the side away from the compressor that is warm to the touch.
Chris
#56 Posted : Saturday, May 12, 2012 1:58:16 AM(UTC)
Your inverter box might be overheating and shutting down periodically. I would check inside to confirm.
Also,measure the input voltage to the fridg when you have a problem.
chrison600
#57 Posted : Saturday, May 12, 2012 12:19:58 PM(UTC)
chrison600
Compressor is currently more noisy than normal. Freezer temp is 7F, but this seems to be the "normal" temp when the compressor is noisy. Voltage at the wall is 122.5 +/- .1.
Chris
#58 Posted : Sunday, May 13, 2012 12:48:19 AM(UTC)
Evidence points to a bad inverter box, unfortunately, there is no easy way to test the compressor except to install a new inverter box. One way to verify the inverter box is bad is to check the total current into the inverter box. Lower than normal current would confirm a bad inverter box.
chrison600
#59 Posted : Sunday, May 20, 2012 10:34:48 AM(UTC)
chrison600
I have a new inverter box (purchased from here), and I'm trying to install it, but I'm having a tough time getting to the connectors on the compressor. I've got the other connectors disconnected and the inverter box out on the floor, but I can't figure out how to get the black plastic cover off of the connector box on the side of the compressor. Without this cover off, I can't get to the connectors at all.
What's the trick to getting that cover off?
Thanks,
Chris
chrison600
#60 Posted : Sunday, May 20, 2012 12:18:02 PM(UTC)
chrison600
Never mind. I got it. New inverter is installed and fridge is plugged back in. Fan and compressor kicked on right away. I've got my fingers crossed.
I also added a 1-outlet APC surge protector to perhaps prevent this fro happening again.
Chris
Guest (10)
7 Pages«<4567>
