At the end of the cycle, it just stays hot; what do I need to replace. I have the schematic.
I cannot find a P00 are you sure it is not a PQ0. The following is for a PQ0 Replacement parts for Whirlpool LER5636PQ0 29"ELECTRIC DRYER | AppliancePartsPros.comSee the attachment for the tech sheet. It includes a timing diagram. Could be a couple things Place timer at the ends of a cycle when cool down should happen. Unplug the unit. Check the timer contacts BK/R. They should be infinite ohms (open). Be sure to disconnect the wires to one of the connectors when checking it. This prevents you from reading an alternate/parallel circuit path. If OK Remove both wire from the heating coil. Check it with the meter, should be 8 to 12 ohms. Then measure from each heating coil connector to a bare spot on the frame. Both should be infinite ohms. If not then the element is grounded and always on. |
THIS FORUM IS DEAD!!!!!!! |
Denman, you are right, it is PQ0. Thanks for the reply. I will check these things and get back to you. Perhaps by Saturday. I appreciate you taking the time to reply to my question. Bernie
I will check on these things Saturday and get back to you. Thanks for taking the time to reply. Bernie
just had a dryer do the same thing to me. I replaced the heating coil and it solved the problem. Guess there was a short somwhere
Thanks guys, for the help. I changed the heating coil, which was broken. Works very well now. Great site, and thanks...
