renegade_7
#1 Posted : Sunday, April 8, 2012 5:20:01 PM(UTC)
renegade_7
At the end of the cycle, it just stays hot; what do I need to replace. I have the schematic.
#2 Posted : Monday, April 9, 2012 7:06:56 AM(UTC)
I cannot find a P00 are you sure it is not a PQ0.
The following is for a PQ0
Replacement parts for Whirlpool LER5636PQ0 29"ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the tech sheet. It includes a timing diagram.
Could be a couple things
Place timer at the ends of a cycle when cool down should happen.
Unplug the unit. Check the timer contacts BK/R.
They should be infinite ohms (open).
Be sure to disconnect the wires to one of the connectors when checking it. This prevents you from reading an alternate/parallel circuit path.
If OK
Remove both wire from the heating coil.
Check it with the meter, should be 8 to 12 ohms.
Then measure from each heating coil connector to a bare spot on the frame. Both should be infinite ohms.
If not then the element is grounded and always on.
renegade_7
#3 Posted : Monday, April 9, 2012 7:08:33 PM(UTC)
renegade_7
Denman, you are right, it is PQ0. Thanks for the reply. I will check these things and get back to you. Perhaps by Saturday. I appreciate you taking the time to reply to my question. Bernie
renegade_7
#4 Posted : Monday, April 9, 2012 7:10:52 PM(UTC)
renegade_7
I will check on these things Saturday and get back to you. Thanks for taking the time to reply. Bernie
ddavis263
#5 Posted : Tuesday, April 10, 2012 7:08:07 AM(UTC)
ddavis263
just had a dryer do the same thing to me. I replaced the heating coil and it solved the problem. Guess there was a short somwhere
renegade_7
#6 Posted : Tuesday, May 8, 2012 2:14:01 PM(UTC)
renegade_7
Thanks guys, for the help. I changed the heating coil, which was broken. Works very well now. Great site, and thanks...
Guest (6)
maytag electric dryer will not cool down (Dryer Repair)
by Ingo 11/9/2010 7:28:00 AM(UTC)
