3 Pages<123>
sidfink43
#11 Posted : Saturday, April 28, 2012 5:16:17 PM(UTC)
sidfink43
Sorry, just replace the timer. That will almost certainly fix it, but if it doesn't and you purchased from this site you can return it, so no risk.
chrisnelson1
#12 Posted : Tuesday, December 4, 2012 5:43:23 PM(UTC)
chrisnelson1
I have the same problem but I did replace the timer and it does the exact same thing. The washer in whole operates perfectly except it won't spin unless I open lid or shut timer off and turn back on. Any other suggestions other than the timer and lid switch?
shmoozer
#13 Posted : Tuesday, December 4, 2012 5:47:18 PM(UTC)
shmoozer
I believe it is the lack of pause in the timer. Did you replace the timer with a NEW unit?
chrisnelson1
#14 Posted : Tuesday, December 4, 2012 6:12:58 PM(UTC)
chrisnelson1
yeah. I ordered from appliance pros, and it does pause before it goes into spin cycle. Its like the clutch is not releasing from some reason. but it pauses for 5 seconds or more after agitating. not sure what do do now...but i know im not buying a new one. ill just keep opening the lid.
chrisnelson1
#15 Posted : Tuesday, December 4, 2012 6:34:15 PM(UTC)
chrisnelson1
you think theres any chance its the start motor capacitor???
shmoozer
#16 Posted : Wednesday, December 5, 2012 2:06:38 AM(UTC)
shmoozer
No, because your motor would not turn at all if it was the start capacitor. It is the pause at that timed moment that causes it to spin after draining. My lid switch was acting up so I replaced it and I just leave the lid up until I am ready to drain and spin. I do not know what to tell you other than keep lifting the lid. I have been doing this for some time now and it is not as much of a bother as I thought it would be; it turns out my clothes get washed faster rather than me forgetting they are there and getting side tracked.
fairbank56
#17 Posted : Wednesday, December 5, 2012 4:31:50 AM(UTC)
fairbank56
Groups: Expert
The pause directly after agitation has nothing to do with neutral drain. That pause is to allow the motor to stop before starting again in the opposite direction. Then it should drain without spin for a minute or two and then pause again. The second pause is to allow the neutral drain to release. Then it will start again spinning and draining. If the pause after drain does not release neutral drain then there's likely something wrong with the neutral drain mechanism in the gearcase. You can rule out the clutch by observing the clutch hub during drain and spin. You must remove the cabinet, bypass the lid switch and observe the clutch hub. During the initial drain period directly after agitate, the clutch hub does not rotate. After the motor pauses and starts again, the clutch hub should be rotating. If it is and the basket is not spinning, then the clutch is slipping.
Eric
UserPostedImage
shmoozer
#18 Posted : Wednesday, December 5, 2012 7:55:27 AM(UTC)
shmoozer
Eric - thanks for that info. If the clutch hub is slipping why would an intensional pause (lifting the lid or pushing in and pulling out the start button) cause the unit to thump into the spin mode?
fairbank56
#19 Posted : Wednesday, December 5, 2012 9:06:47 AM(UTC)
fairbank56
Groups: Expert
I don't have an answer for that, but observing the clutch hub would certainly tell us where to look further.
Eric
LoXodonte
#20 Posted : Tuesday, March 6, 2018 7:23:36 AM(UTC)
LoXodonte
I'm not an appliance guy, but I dabble in troubleshooting...I'm not buying into the timer cure-all solution presented here. I mean, haven't clocks been around for a millennia or two? I want to assume humanity has mastered the clock by now.
In my case my washer was recently repaired for making a clunking sound during agitation...it was only AFTER the appliance guy worked on my unit that I started having issues with the spin not engaging. In addition, the unit makes a strange hum noise when it is supposed to be spinning but isn't. I have also observed what sounded like a shot of water being introduced during the spin cycle, which I honestly assumed should not be happening...this was the only potential symptom I observed that MAY be related to the timer. Even then that could be normal, and I still wouldn't suspect the timer hardware if it were abnormal.... I'd suspect the numb-nuts who botched the repair that caused this issue. Perhaps the timer can be calibrated?
3 Pages<123>
