3 Pages<123>
#11 Posted : Tuesday, April 24, 2012 1:33:40 PM(UTC)
Originally Posted by: spoony Go to Quoted Post
...Set on 200 scale...
...the fan motor near the compresser is turning slow...
This scale is wrong to measure K ohms. You have to set it on a higher scale and redo the test.
How hot on touch is the compressor?
spoony
#12 Posted : Wednesday, April 25, 2012 8:19:35 AM(UTC)
spoony
Hi,Gene Thanks for all the help.
The compresser is HOT to touch.
And from Terminal J9 to J7-9 it reads 26
and from pin J1 to J1-4 reads 16 and J1 to J1-5 reads 11
on 2000k scale.
#13 Posted : Wednesday, April 25, 2012 5:18:14 PM(UTC)
Seems like you did the tests correct and there are nothing wrong with the defrost parts in the freezer. I believe you have to replace the main control board and the condenser fan motor to fix it.
It's better not to use the fridge until you'll do it. Otherwise it can damage the compressor. If you don't have a spare fridge, put a regular fan to blow a cool air on the compressor.
- The main control board Part number: WR55X10942
- The condenser fan motor Part number: WR60X10209
spoony
#14 Posted : Thursday, April 26, 2012 9:40:01 AM(UTC)
spoony
Hi Gene,
If I buy the main control board and it wasn't the problem can i return it ? and 1 more thing if I set the temp.control to a lower temp it go's
back to the old temp. right away.As that normal?
Please let me no and thanks for the help
Woodie:)
#15 Posted : Thursday, April 26, 2012 11:12:58 AM(UTC)
Woodie,
As you can see from my signature, you always can return any part purchased from APP. Order these two parts and give it a try.
spoony
#16 Posted : Saturday, May 12, 2012 6:29:33 AM(UTC)
spoony
Hi Gene,
Well I replaced the main control board and the condenser fan motor now fan runs faster but the temp.inside both the refrigerator and the freezer did not change. refrigerator is at 56 and freezer is at 28 and will not get colder
then that. a lot of frost in the freezer back wall.is there something to reset
with the new control board ? i am ready to blow this up!!!!
What do you think ? Thanks for the help...:) Woodie
Temperature sensors ??
#17 Posted : Monday, May 14, 2012 1:31:45 PM(UTC)
Hi Woodie,
Did you clean the condenser coils?
Did you install the cover for the machine compartment back in place?
Remove the rear panel inside the freezer and check how the evaporator coils are covered with frost. Post the results.
spoony
#18 Posted : Tuesday, May 15, 2012 2:32:57 PM(UTC)
spoony
Hi Gene,
I did put all covers back on and I clean the condenser coils.
But to day the freezer was at 0 and the frig.was at 31 and it will no change at all with the controls . (warmer ,colder Pads.
and i found water on the bottom of unit.
Thanks for the HELP woodie:)
#19 Posted : Tuesday, May 15, 2012 2:40:51 PM(UTC)
...it will no change at all with the controls . (warmer ,colder Pads...
After you changed the temperature setting, you have to wait about 24 hours to see a result.
P.S. Where did you find water? Was it water or ice?
spoony
#20 Posted : Tuesday, May 15, 2012 2:54:00 PM(UTC)
spoony
it was 24 hours and no change and the water was were the tube is on the bottom near the compresser were it go's to de-frost.Thanks,Woodie:)
Guest (4)
3 Pages<123>
