I have a whirlpool fridge with a filtered water dispenser on the inside, and all of a sudden my filtered water dispenser doesn't give me any water. It still makes noise like its working, but no water comes out. Ice maker still working fine. Any ideas?
Is it time to change the filter?
Disconnect the water line where it comes out of the water inlet valve on the back of the fridge. Then try the water dispenser and see if water comes out there. If not the valve is bad OR swap the wires on the valve and try the water dispenser. The water should come out at the ice maker if the valve works.
Disconnect the line where it goes into the freezer door at the bottom. Try the water dispenser. If it comes out there then the line may be frozen in the door. Us a hairdryer to thaw it where the water is supposed to come out.
