5 Pages«<2345>
supercliff
#31 Posted : Thursday, April 12, 2012 12:18:20 PM(UTC)
supercliff
Hello Gene,
thanks so much for your help. If I understand correctly, I will need to check/replace all of the crimped wires which attach to the water valve which looks like:
http://www.appliancepartspros.c...TFBXL3NvdG9ocHRyYXAv.jpg
and it is located as #2 here:
Cabinet - rear (washer) replacement parts for Maytag MHW2000AWW STACKED WASHER | AppliancePartsPros.com
Also, can you tell me where #2 is located on the back of the machine? From what I can see it Item # 2 connects to item #5 which I believe attaches to the upper right of item # 1
Thanks again!
#32 Posted : Thursday, April 12, 2012 12:45:14 PM(UTC)
Before you'll start to disassemble it, describe how did it stop please. Did it stop at the same point or it was different every time? How did it fill up with cold water?
supercliff
#33 Posted : Thursday, April 12, 2012 12:58:46 PM(UTC)
supercliff
My tenant told me it always stops leaving her clothes wet and soapy. I'm going to assume that means it stops in the same location each time. The work around my previous tenant use was to turn the dial around and back to where it left off and restart the machine.
#34 Posted : Thursday, April 12, 2012 1:12:03 PM(UTC)
It is very important to find out if it fills up with cold water.
supercliff
#35 Posted : Thursday, April 12, 2012 6:58:28 PM(UTC)
supercliff
Should I tell them to run a load with cold/cold and see if any water comes out? Or is there a better way to do that?
#36 Posted : Monday, April 16, 2012 12:42:29 PM(UTC)
Originally Posted by: supercliff Go to Quoted Post
...Should I tell them to run a load with cold/cold and see if any water comes out?...
Yes, it should work.
Janesl36@frontiernet.net
#37 Posted : Wednesday, September 12, 2012 10:52:29 AM(UTC)
Hello Gene, i have a maytag neptune washer, model mah5500bww, starts,fills up,runs, then stops during wash cycle, water in drum w/ clothes, no error codes, try to do spin cycle, it starts, then stops, timer goes to 0 from 9, if i hold dwn delicatesbutton and heavy soil button at same time for 3 secs and then do spin, water pumps out, but display goes off and drum spins forever, until i unplug machine, any thoughts? thanks
#38 Posted : Wednesday, September 12, 2012 12:01:26 PM(UTC)
Open the control panel. Remove the control board and visually inspect for any burned (discolored) resistors. Post the results. Post the serial number if the washer.
#39 Posted : Wednesday, September 12, 2012 12:41:08 PM(UTC)
will do tomorrow, thanks, i am also changing the large rubber gasket in front of the drum, it is ripped in a couple of spots, would this have anything to do with my problem?
#40 Posted : Thursday, September 13, 2012 4:53:38 AM(UTC)
control panel looked fine, serial number is A2926000n
5 Pages«<2345>
