lrodriguez
#1 Posted : Tuesday, November 27, 2007 8:32:13 PM(UTC)
lrodriguez
I have a crosley washer it work find until the transmission stop working...so the transmission has been replace and now it doesn't spin and everything looks good belt, brakes etc. We put it on the test and it washes drains the water but it doesn't spin. Can I get your opinion on this?
Thanks,
Rodriguez
okbobcats
#2 Posted : Wednesday, November 28, 2007 3:39:37 AM(UTC)
okbobcats
your brake could be dragging. or just a loose belt. try turning the the pulley on transmission to see if your barke releases.
lrodriguez
#3 Posted : Wednesday, November 28, 2007 9:29:28 AM(UTC)
lrodriguez
Belt was checked and its not loose. The brake did that had to go back on with a special tool?..everything looks fine. Would you suggest to change the brake?
Thanks,
Rodriguez
justine bowen
#4 Posted : Saturday, November 15, 2008 9:34:18 AM(UTC)
justine bowen
I Need To Replace Belt On A Crosley
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
