I have a crosley washer it work find until the transmission stop working...so the transmission has been replace and now it doesn't spin and everything looks good belt, brakes etc. We put it on the test and it washes drains the water but it doesn't spin. Can I get your opinion on this? Thanks, Rodriguez
your brake could be dragging. or just a loose belt. try turning the the pulley on transmission to see if your barke releases.
Belt was checked and its not loose. The brake did that had to go back on with a special tool?..everything looks fine. Would you suggest to change the brake? Thanks, Rodriguez
I Need To Replace Belt On A Crosley
