appliance~nightmares
#1 Posted : Monday, March 16, 2009 12:32:45 PM(UTC)
Ok, my hubby decided to wash 3 loads of laundry and well now the dryer is not working:mad: no heat, no codes, any help would be great its a whirlpool senseon GEW9868KQ0 what is the first thing to check he did say he got a ton of lint out after taking cover off. thanks for any help
#2 Posted : Monday, March 16, 2009 2:24:27 PM(UTC)
Here are the parts
Replacement parts for WHIRLPOOL GEW9868KQ0 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%203979121.pdf
First turn your breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
Better yet check with a meter to see if you have 220 volts at the plug.
Next would be the thermal fuse (Cutoff) in the heater line.
Replace if blown.
If it is gone clean and check the vent system and the unit's blower wheel.
If there is lots of lint in the unit check that the drum seals are OK.
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
