grant
#1 Posted : Monday, November 26, 2007 6:37:34 PM(UTC)
grant
maytag washer has developed a severe grinding noise on the spin cycle is it something that can be repaired or is it finished
thanks for the help
grant
#2 Posted : Tuesday, November 27, 2007 2:42:30 PM(UTC)
Most likely the problem with your washer is a bad pump bearing.
Lift the washer up from the front, remove the belt and rotate the pump pulley manually. If you feel any tension, replace the pump.
- The part number for the pump AP3447809
- Here are the break down diagrams for the Maytag washer Model MAV6200AWW
grant
#3 Posted : Tuesday, November 27, 2007 4:49:31 PM(UTC)
grant
thanks a lot Gene,you were correct the pump is bad, saved me a bundle
GE washer Problems w/ Agitation GCWN3000M1WS (Washer Repair)
by ps33 12/19/2020 4:19:13 PM(UTC)
Kenmore VMW 22352 Washer Problems (Washer Repair)
by Papa_omero 3/11/2019 5:25:53 PM(UTC)
Whirlpool Duet Sport Washer problems (Washer Repair)
by bdmbluegrass 1/11/2017 11:54:22 AM(UTC)
washer problems (Washer Repair)
by porterbridges 1/18/2015 10:53:23 AM(UTC)
by Revelation320 9/4/2013 4:41:04 PM(UTC)
Commerical Washer Problems (Washer Repair)
by sherryash 12/18/2012 3:11:25 PM(UTC)
by mariela 10/24/2012 7:44:31 PM(UTC)
Bosch Dishwasher problems (Dishwasher Repair)
by Manuel Arce 9/15/2012 9:14:41 AM(UTC)
Whirlpool dishwasher Problems (Dishwasher Repair)
by captbud 8/1/2012 10:21:44 AM(UTC)
by malon66 6/21/2012 6:17:18 PM(UTC)
WP Ultimate Care 2 washer problems...new timer didn't fix (Washer Repair)
by HunterTinsley 4/6/2012 6:11:49 PM(UTC)
Whirlpool Washer Problems (Washer Repair)
by GK12 3/4/2012 1:28:37 PM(UTC)
LG Dishwasher problems HELP! (Dishwasher Repair)
by djmcheme 11/19/2011 11:05:29 AM(UTC)
Intermittent washer problems (Washer Repair)
by rscha787 10/12/2011 5:56:35 PM(UTC)
by jamesnl 10/9/2011 2:13:43 PM(UTC)
