shoman
#1 Posted : Saturday, March 24, 2012 6:36:59 AM(UTC)
shoman
Freezer recently began warming up.....it won't go below 25 degrees......fridge section seems ok.
No ice buildup except for top of defrost thermstat.
I've cleaned all dust buildup at bottom of the refrigerator
Unit was not cycling off for many weeks.....recent electric bill was VERY high.
Fan in rear is fine, compressor is warm and seems to be running/humming normally.
Just let unit thaw overnight and now fan in freezer is not spinning and unit doesn't seem cold at all!
HELP!
ApplianceJunk
#2 Posted : Saturday, March 24, 2012 10:15:27 AM(UTC)
ApplianceJunk
Sounds like a sealed system problem. Either a refrigerant leak or the compressor is week.
With the age of it you may just want to look for a new one.
shoman
#3 Posted : Sunday, March 25, 2012 6:18:40 AM(UTC)
shoman
Update: I metered the defrost timer and 1 and 3 circuit failed the continuity test. Could this contribute and/or fix my problem? I'd much rather spend a little money than replace my entire fridge....
Thank you!
shoman
#4 Posted : Sunday, March 25, 2012 6:24:27 AM(UTC)
shoman
Thank you!
Second Update: Removed coil cover in freezer - fan was blowing fine but only the top 3 rows of coils were frosty and cold.....does this help confirm that I've possibly got a low coolant problem? Thanks Again
ApplianceJunk
#5 Posted : Sunday, March 25, 2012 6:28:32 AM(UTC)
ApplianceJunk
Confirms that you have a sealed system problem. Low on refrigerant, restriction in the capillary tube or a week compressor.
To correctly troubleshoot it I would solder on some valves so I could attach some gauges to see what the pressures read.
Guest (4)
Whirlpool Top-Mount Freezer won't freeze (Refrigerator & Freezer Repair)
by Regalhank 11/29/2016 6:58:46 AM(UTC)
Freezer won't freeze after advancing defrost timer (Refrigerator & Freezer Repair)
by MightySky 7/8/2013 7:33:03 PM(UTC)
Upright Freezer won't freeze and makes loud noise (Refrigerator & Freezer Repair)
by Renatefry 2/20/2013 5:15:25 PM(UTC)
by Renatefry 2/20/2013 5:02:07 PM(UTC)
Freezer won't freeze, fridge not that cold (Refrigerator & Freezer Repair)
by otison 1/28/2012 10:26:29 AM(UTC)
frigidaire freezer won't freeze an fridge isn't cold as should be. (Refrigerator & Freezer Repair)
by auralight1 1/22/2012 8:07:33 AM(UTC)
by duncanj 10/30/2011 7:16:33 AM(UTC)
Fridge Cold, Freezer won't freeze all the time (Refrigerator & Freezer Repair)
by darrellwass 10/21/2011 6:59:02 AM(UTC)
Freezer Won't Freeze, Both Sides Stuck at @ 40ยบ (Refrigerator & Freezer Repair)
by obx166ec 10/7/2011 3:53:35 PM(UTC)
freezer won't freeze (Refrigerator & Freezer Repair)
by Gpa 4/28/2011 12:12:30 PM(UTC)
Refrigerator freezer won't freeze (Refrigerator & Freezer Repair)
by bittersweet 12/16/2010 10:53:30 AM(UTC)
Freezer Won't Freeze (Refrigerator & Freezer Repair)
by leichte 11/10/2010 3:13:48 AM(UTC)
by blancapaloma5290 8/13/2010 11:42:02 AM(UTC)
freezer won't freeze anymore (Refrigerator & Freezer Repair)
by 1967hammer 9/6/2008 7:56:26 AM(UTC)
HotPoint Refrigerator's Freezer won't freeze (Refrigerator & Freezer Repair)
by RHCHomeowner 7/18/2008 7:02:39 PM(UTC)
