tonyg42
#1 Posted : Sunday, November 25, 2007 10:52:02 AM(UTC)
tonyg42
My admiral Dryer stopped mid cycle and there is no response the timer is still ticking but the internal light doesn't come on when door is open and i have proper voltage into and leaving timer and at the door switch it ohms out as good also, is ther a fuse or switch in line somewhere on this model if so where would it be located. Thanks for any helpful info
Admin / APP Team
#2 Posted : Sunday, November 25, 2007 1:33:41 PM(UTC)
Admin / APP Team
Rank: Administration
Groups:
Tony, your dryer model is LNC7764A71, not LCN. Direct link to breakdown diagrams and parts for Model LNC7764A71.
Check the thermal fuse for continuity (unplug the dryer power cord first!). This is an electric dryer, so it needs 220 volts to operate. You would only have 110 volts at the timer or at the door switch. There are two dryer circuit breakers inside the house subpanel. They're side by side and are hopefully marked as "dryer". One of them might be tripped. Reset both breakers. If you know how to use a voltmeter, make sure there is 220 volts at the dryer wall socket.
- Wiring diagram for LNC7764A71
Thermal fuse now comes as a kit which includes the hi-limit thermostat. Replace the fuse (as well as the hi-limit thermostat) if it shows no continuity.
- Thermostat/Thermal fuse kit (instructions included)
Hope this helps.
tonyg42
#3 Posted : Monday, November 26, 2007 6:30:05 AM(UTC)
tonyg42
Thanks for the info about my dryer i did find the thermal fuse link to be bad meaning no continuity it took about 30 minutes to get the dryer apart to find it because there was no detail drawing on its location but it was mounted to the heater element box that is behind the drum. So the part is on order and we should be up and running soon. Thanks again:)
Admin / APP Team
#4 Posted : Tuesday, November 27, 2007 11:41:48 AM(UTC)
Admin / APP Team
Groups:
Good to hear that, Tony. We'll get that fuse to you in no time.
ofblong
#5 Posted : Monday, March 2, 2009 5:05:27 PM(UTC)
ofblong
Sweet thanks for this thread. I knew the fuse was bad on my dryer cause i read the print that was taped up behind the control panel and thats the only thing I could see that could be wrong. but until I found this page I had no idea where the fuse was lol. Good thing I now feel stupid nowing its right in plain view and easily accessable lol. either way your site seems to be the cheapest for this so I just ordered one :D. Sorry for bringing back a 2 yr old thread but I was excited to find something about my 8 yr old dryer.
Dryer Repair Again and Again (Dryer Repair)
by Guest 6/25/2022 3:48:47 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Dryer repairs (Dryer Repair)
by P3FE 10/16/2021 2:36:49 PM(UTC)
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 3/19/2020 12:26:10 PM(UTC)
Dryer Repair Issue (Dryer Repair)
by jdharrin 10/2/2019 1:32:57 PM(UTC)
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 2/2/2018 5:35:41 PM(UTC)
Dryer repair Help! (Dryer Repair)
by Hah45 10/4/2017 2:39:32 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 12/26/2015 12:03:59 PM(UTC)
Dryer Repair (Dryer Repair)
by sotomargie 12/21/2015 9:44:35 AM(UTC)
Dryer repair (Dryer Repair)
by dchurch 9/26/2015 8:38:17 AM(UTC)
by jaybick 8/24/2015 6:34:15 AM(UTC)
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10/13/2014 10:54:09 AM(UTC)
by Tom Campion 4/14/2014 6:20:19 AM(UTC)
by kencorey281@gmail.com 11/12/2013 2:35:48 PM(UTC)
