mistahpaul
#1 Posted : Wednesday, March 4, 2009 7:39:05 AM(UTC)
mistahpaul
The washer fills it will also spin but when the agitator trys to engage it just makes a hum noise.
gls674
#2 Posted : Wednesday, March 4, 2009 10:07:37 AM(UTC)
gls674
does the washer leak at all? I'm guessing either you have a bad belt or the stem kit (bearing is locked up? usually it will leak and be oily on the floor of the washer
mistahpaul
#3 Posted : Wednesday, March 4, 2009 10:44:06 AM(UTC)
mistahpaul
no leaks just a buzz when the agitator should start
gls674
#4 Posted : Wednesday, March 4, 2009 10:56:17 AM(UTC)
gls674
have you had the front of the washer off yet? heres a new thought the motor sits on the left corner on glides...
are those glides sticky? try pulling back in the motor.. see if it engages
gls674
#5 Posted : Wednesday, March 4, 2009 10:58:14 AM(UTC)
gls674
does it pump the water out?
mistahpaul
#6 Posted : Thursday, March 5, 2009 9:13:53 AM(UTC)
mistahpaul
the motor glides ok, I have to check if it drains the water.
Guest (4)
Washer bottom agitator not working (Washer Repair)
by Hondo64 3/10/2019 8:48:46 AM(UTC)
Agitator not working properly (Washer Repair)
by Morina 11/29/2014 11:20:51 AM(UTC)
by jamesdean 6/12/2014 6:08:58 PM(UTC)
Agitator not working correctly (Washer Repair)
by phyllsplace 10/5/2013 8:49:31 AM(UTC)
washer's agitator not working (Washer Repair)
by jmseva 4/10/2013 5:00:23 PM(UTC)
top agitator not working (Washer Repair)
by peeteW 11/27/2012 2:47:17 AM(UTC)
Washer agitator not working and not draining (Washer Repair)
by dferd3 7/23/2012 2:45:14 PM(UTC)
Agitator not working, squealing noise (Washer Repair)
by lderubeis 3/17/2012 11:34:59 PM(UTC)
Agitator not working (Blender Repair)
by tbanks204 2/22/2012 8:40:44 PM(UTC)
Washer agitator not working (Washer Repair)
by dm3 12/17/2011 9:45:45 AM(UTC)
Agitator not working correctly. (Washer Repair)
by martiwood1 5/14/2011 5:32:06 PM(UTC)
washer agitator not working (Washer Repair)
by Mane 1/3/2011 6:38:09 AM(UTC)
Estate by Whirlpool upper agitator not working (Washer Repair)
by sigtauenus 12/25/2010 12:00:56 PM(UTC)
Agitator Not Working (Washer Repair)
by habes 6/14/2010 1:01:22 PM(UTC)
Top agitator not working properly (Washer Repair)
by chris77 2/1/2010 8:04:51 AM(UTC)
