The washer fills it will also spin but when the agitator trys to engage it just makes a hum noise.
does the washer leak at all? I'm guessing either you have a bad belt or the stem kit (bearing is locked up? usually it will leak and be oily on the floor of the washer
no leaks just a buzz when the agitator should start
have you had the front of the washer off yet? heres a new thought the motor sits on the left corner on glides... are those glides sticky? try pulling back in the motor.. see if it engages
does it pump the water out?
the motor glides ok, I have to check if it drains the water.
