dryer stopped heating, replaced the heating element, but still get cold air, no heat.
i am looking at maybe replacing the thermostat, however, is there anything else i need to check and trouble shoot prior to just buying any part?
ok guess i need to find an ohmmeter, just read other posts looking similiar to my problem.
You might want to flip your dryer breaker off and on a few times, to see if it has partially flipped. If not it will most likely be the thermal fuse. Tom ApplianceEducator.com
Here are the parts Model LER4634EQ1Here is the wiring diagram https://www.servicematters.com/d...0Sheet%20-%203406688.pdfYou will see a thermal cutout on the wiring diagram in the heater circuit. See Item 6 in Section 3 You can check this by unplugging the machine, removing the wires and shorting them together, tape them up so they cannot short to the frame and give it a try. If now OK replace it ASAP as it is a safety device. Replace the set. Give the interior a good clean. Also clean and check your vent system to ensure you have good air flow out the exhaust. |
THIS FORUM IS DEAD!!!!!!! |
as in the main breaker box where all breakers are? or is there a breaker switch on the unit itself i need to locate and check?
ok, main breaker, all is ok there. i threw the switch off and then back on.
and as, to the thermal fuse, i taped the 2 wires together and still get no heat.
as far as operating the unit runs, quiet, blows out exhaust very good, just that its cold air, like a fan set on high speed.
now , if i was to replace thermostats do i need to replace thermal fuse at same time, or should that not have a factor after thermostats are replaced?
Before you do that does your timer advance in Auto mode? |
