dego
#1 Posted : 16 years ago
dego
dryer stopped heating, replaced the heating element, but still get cold air, no heat.
i am looking at maybe replacing the thermostat, however, is there anything else i need to check and trouble shoot prior to just buying
any part?
dego
#2 Posted : 16 years ago
dego
ok guess i need to find an ohmmeter, just read other posts looking similiar to my problem.
kayakcrzy
#3 Posted : 16 years ago
kayakcrzy
You might want to flip your dryer breaker off and on a few times, to see if it has partially flipped. If not it will most likely be the thermal fuse. Tom ApplianceEducator.com
#4 Posted : 16 years ago
Here are the parts
Model LER4634EQ1
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203406688.pdf
You will see a thermal cutout on the wiring diagram in the heater circuit.
See Item 6 in Section 3
You can check this by unplugging the machine, removing the wires and shorting them together, tape them up so they cannot short to the frame and give it a try.
If now OK replace it ASAP as it is a safety device. Replace the set.
Give the interior a good clean. Also clean and check your vent system to ensure you have good air flow out the exhaust.
dego
#5 Posted : 16 years ago
dego
as in the main breaker box where all breakers are? or is there a breaker switch on the unit itself i need to locate and check?
#6 Posted : 16 years ago
Main breaker box
dego
#7 Posted : 16 years ago
dego
ok, main breaker, all is ok there. i threw the switch off and then back on.
and as, to the thermal fuse, i taped the 2 wires together and still get no heat.
as far as operating the unit runs, quiet, blows out exhaust very good, just that its cold air, like a fan set on high speed.
now , if i was to replace thermostats do i need to replace thermal fuse at same time, or should that not have a factor after thermostats are replaced?
#8 Posted : 16 years ago
Before you do that does your timer advance in Auto mode?
dego
#9 Posted : 16 years ago
dego
[/URL]
the answer i found was in this post: [url]http://forum.appliancepartspros.com/dryer-repair/24634-dryer-repair.html
after realizing the difference between the cut-off and the fuse, i taped the cut-off together and it started heating no problem.
now, i guess i need to replace both thermostats? or just the top one?
the high end thermostat has 3 prongs on it, the kits i saw on your site has 2 prongs. do i need to get these individually?
and thanks and many praises to this helpful forum, i will highly recommend this site to anyone needing help on appliances.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 11 months ago
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest about a year ago
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag about a year ago
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam about a year ago
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 about a year ago
No heat when assembled (Dryer Repair)
by Guest 2 years ago
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2 years ago
No heat, (Dryer Repair)
by tseibring 2 years ago
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 2 years ago
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 3 years ago
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 3 years ago
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 3 years ago
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 3 years ago
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
