Gern Blanston
#1 Posted : Tuesday, January 24, 2012 8:16:18 AM(UTC)
Gern Blanston
There is a small amount of water leaking from somewhere near the motor and pump. Hose inspection found no leaks. I can't seem to find where the water is coming from. Any suggestions? Is that pump housing made of plastic?
ApplianceJunk
#2 Posted : Tuesday, January 24, 2012 8:59:31 AM(UTC)
ApplianceJunk
Yes, the water pump housing is made of plastic. :(
99% of the time I find the leak is from the water pump.
The other times I find a hole in the outer tub.
You may find this topic helpful.
http://appliancejunk.com...s/index.php?topic=9050.0
Whirlpool washer leaks from front - replaced pump... still leaks! (Washer Repair)
by metadog 2/17/2013 4:34:39 PM(UTC)
whirlpool washer leaks (Washer Repair)
by mdeagan 3/16/2012 1:54:39 PM(UTC)
Whirlpool washer leaks at certain time of cycles (Washer Repair)
by Pegleg37 10/4/2011 10:16:55 AM(UTC)
Whirlpool washer leaks from front while filling (Washer Repair)
by bobandjayne 4/27/2011 12:08:00 PM(UTC)
Whirlpool washer leaks (Washer Repair)
by jstevens 9/19/2009 9:16:54 AM(UTC)
by modelshop8624 5/17/2009 7:28:08 PM(UTC)
by pritch99 12/10/2008 10:51:19 AM(UTC)
by billmac77 8/5/2008 4:39:07 PM(UTC)
