tompar5
#1 Posted : Tuesday, January 17, 2012 11:52:38 AM(UTC)
tompar5
Have an F# code. Oven sensor open. Checked with meter and get 1091 ohms at the sensor plug. Tried at the plug going into the control panel and get the same. Is the sensor really "open" at 1091 or is there a fault in the control board?
#2 Posted : Tuesday, January 17, 2012 3:14:21 PM(UTC)
If it reads 1091 Ohms at the control board plug then the problem is a bad control board.
- The control board Part number: AP2150432
Oven Sensor Replacement (Oven Repair (including Ranges and Cooktops))
by jscuozzo 11/19/2013 4:46:17 PM(UTC)
faulty oven sensor ????? (Oven Repair (including Ranges and Cooktops))
by Orlando8 6/16/2013 10:54:59 AM(UTC)
Oven Sensor Issue (Oven Repair (including Ranges and Cooktops))
by epic1231 10/28/2012 2:40:48 PM(UTC)
Oven sensor (Oven Repair (including Ranges and Cooktops))
by Kathyl 8/16/2012 12:37:36 PM(UTC)
replace oven sensor whirlpool (Oven Repair (including Ranges and Cooktops))
by vaught 4/26/2012 8:04:50 AM(UTC)
Stumped! Replaced Oven Sensor, Still Not Working! (Oven Repair (including Ranges and Cooktops))
by Debelli 12/4/2010 11:13:00 AM(UTC)
Need new Oven Sensor (Oven Repair (including Ranges and Cooktops))
by lynnie 11/24/2009 5:01:03 PM(UTC)
Checking the oven sensor resistance (Oven Repair (including Ranges and Cooktops))
by Joe the fixer 10/29/2009 10:08:51 PM(UTC)
Show Me How to replace Jenn-air oven sensor (Oven Repair (including Ranges and Cooktops))
by shokwaves 10/26/2009 2:15:46 AM(UTC)
Testing an Oven Sensor (Refrigerator & Freezer Repair)
by shokwaves 10/7/2009 1:47:46 AM(UTC)
Jenn Aire WG30100 oven sensor replacement (Oven Repair (including Ranges and Cooktops))
by szyglowicz 9/9/2009 4:55:50 AM(UTC)
How to replace oven sensor? (Oven Repair (including Ranges and Cooktops))
by donsmullen 7/11/2009 10:14:14 AM(UTC)
by Warren F-150 5/28/2009 7:15:49 AM(UTC)
How do you replace an oven sensor? (Oven Repair (including Ranges and Cooktops))
by kschrei 5/28/2009 4:39:22 AM(UTC)
F3 on Frigidaire after replacing oven sensor (Oven Repair (including Ranges and Cooktops))
by undercookedinPDX 11/27/2008 11:29:54 AM(UTC)
