makoa
#1 Posted : Sunday, January 15, 2012 12:42:11 PM(UTC)
makoa
Dishes not as clean anymore. bottom spininer arm seems to be moving well, not sure about upper spinner arm. i mark location, seems hard to tell if its rotating or just moved a little. just bought new logic control board and whole new switch panel and installed them. Runs full cycles. HELP !
#2 Posted : Monday, January 16, 2012 3:09:08 AM(UTC)
Here are your parts.
First check the holes in the spray arm to be sure they are clear.
If clogged I find it easiest to clean them by starting a cycle so the debris is wet and then pulling it out with tweezers.
taking them off and rinsing them out often leaves crud in them so is not reliable.
Check that the filters are clean.
Check the water level. Most units fill to just under the heating element.
A good way to check is to add a couple quarts of hot water after a fill to see if it then runs OK. Just be careful to not over fill it.
Often the pump will be noisier if it is starving for water.
If it now washes OK then I would check the screen filter on the input side of the water valve for a partial plug. If dirty clean it. Do not permanently remove it from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
Dirty dishes problem (Dishwasher Repair)
by cmeek711 3/1/2014 5:40:21 AM(UTC)
Dirty dishes (Dishwasher Repair)
by bdccjc 4/20/2013 11:52:41 AM(UTC)
GE Profile dirty dishes and black specks (Dishwasher Repair)
by jaynoll80 2/28/2013 5:18:03 PM(UTC)
dirty dishes (Dishwasher Repair)
by ginger4683 11/5/2012 1:22:46 PM(UTC)
by gregrust 12/21/2011 3:11:45 PM(UTC)
Dishwasher Top Rack Dirty Dishes (Dishwasher Repair)
by jdh06 5/12/2011 4:31:02 PM(UTC)
dirty dishes/impeller (Washer Repair)
by winewino 4/23/2011 1:23:58 PM(UTC)
Dirty Dishes on bottom Rack (Dishwasher Repair)
by Derekclarke03 4/22/2011 6:29:08 AM(UTC)
Dirty dishes maytag dishwasher (Dishwasher Repair)
by goldbryant 4/11/2011 2:59:43 PM(UTC)
Frigidaire Dishwasher - top rack dirty dishes (Dishwasher Repair)
by officework13 3/15/2011 2:00:28 PM(UTC)
Dirty Dishes - Bosch Dishwasher (Dishwasher Repair)
by mcerods 1/22/2011 5:39:06 AM(UTC)
scummy and dirty dishes (Dishwasher Repair)
by jackofall? 1/16/2011 11:51:07 AM(UTC)
dirty dishes Maytag dishwasher (Dishwasher Repair)
by bobp0626 7/23/2010 3:18:50 PM(UTC)
Dirty Dishes-Whirlpool Gold Quiet partner III (Dishwasher Repair)
by kfitzpat9 3/30/2010 6:07:53 PM(UTC)
General fix for dirty dishes glasses upper rack (Dishwasher Repair)
by skylimit1959 9/29/2009 4:33:01 PM(UTC)
