2 Pages12>
bdccjc
#1 Posted : Saturday, April 20, 2013 11:52:41 AM(UTC)
bdccjc
My dishes are not getting clean. The soap dispenser is not clearing out completely. I believe i may have a defective pump or scale build up in a inlet filter. I have checked the upper lever spray tower for debris. It is clear. The internal water level float appears to be clear. What else should I check.
#2 Posted : Sunday, April 21, 2013 1:09:28 AM(UTC)
Was thanked: 10 time(s) in 10 post(s)
Parts for GE GSD2000G00BB Dishwasher - AppliancePartsPros.com
The float switch should not effect wash performance unless it is not letting any water into the unit. It is just an overflow safety device.
A common problem is the unit not filling with enough water.
Most units fill to just under the heating element.
This can be checked by adding a couple quarts of water after each fill during a cycle.
Just be careful to not overfill it.
If it now washes OK then check the fill valve.
Often if the fill is low you will also hear a growling sound because the pump will cavitate (suck in air).
The most common cause is a dirty screen filter on the input side of the fill valve. Remove the valve from the unit and clean/check the filter.
Do not permanently remove it from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
If it still does not fill correctly I would replace the fill valve.
PS: Be sure to shut off the power and the water supply to the unit. Have paper towels etc. handy to wipe up any spilled water. Get a small pan/bowl etc. that will fit under the valve then loosen the input water line let it drip into the container emptying it as necessary. This will minimize the amount of water spilled.
bdccjc
#3 Posted : Sunday, July 7, 2013 2:24:18 PM(UTC)
bdccjc
I have pulled the fill valve and cleared the inlet screen. There was a little debris, but not blocked. Upon reassembly and testing a cycle, I think it may be the fill valve is not working. I have tried to manually fill the basin with water, however the unit runs a drain cycle upon closing the door and starting the cycle. Is that normal? I am trying to run a full cycle currently to check the operation.
bdccjc
#4 Posted : Monday, July 8, 2013 9:45:00 AM(UTC)
bdccjc
I have ran a full cycle. Still not enough water pressure to knock a dry paper towel out of a cup on the top rack. The towel was barely damp, and still in place in the cup where I placed it.
#5 Posted : Tuesday, July 9, 2013 12:52:25 AM(UTC)
I would replace the fill valve if at the start of a wash cycle you open the door and add a couple quarts of hot water and it then cleans the dishes OK.
Just be careful to not overfill the unit.
bdccjc
#6 Posted : Tuesday, July 9, 2013 7:34:54 AM(UTC)
bdccjc
Immediately after shutting the door to when adding water, the unit drains for about 5 seconds. Then it sounds like it is spinning for about a minute. Next it runs water for almost 30 seconds and starts a the cycle. Is that normal operation?
bdccjc
#7 Posted : Tuesday, July 9, 2013 12:52:20 PM(UTC)
bdccjc
Upon the completion of this cycle, I still have dirty dishes on the top shelf. with the bottom clean. Is this still the fill valve?
#8 Posted : Wednesday, July 10, 2013 2:12:56 AM(UTC)
[COLOR="Blue"]Immediately after shutting the door to when adding water, the unit drains for about 5 seconds. Then it sounds like it is spinning for about a minute. Next it runs water for almost 30 seconds and starts a the cycle. Is that normal operation?[/COLOR]
I cannot say as I do not have a cycle chart for this unit.
[COLOR="Blue"]Is this still the fill valve?[/COLOR]
What is the water level after it runs the water for 30 seconds.
This is when you should add water to see if the fill is not enough.
bdccjc
#9 Posted : Friday, September 6, 2013 7:29:00 AM(UTC)
bdccjc
The unit drains simultaneously as it is filling. It starts by filling for about five seconds, then the drain starts to run. This cycle alternates for about 30-40 seconds. After this stops, the pump sounds like it is dry. I then opened the unit and filled about 2 quarts of water. Once I closed the door the unit fully drained all water I just added. I am sorry I haven't follow up sooner on this, I haven't had the time to check and finish this lately. I plan on getting this project completed in the next couple of days. Thanks for your patience. Does this still sound like the fill valve or could I have other issues effecting the proper sequencing of this unit?
#10 Posted : Saturday, September 7, 2013 6:53:19 AM(UTC)
[COLOR="Blue"] Does this still sound like the fill valve or could I have other issues effecting the proper sequencing of this unit?[/COLOR]
Does not sound like a fill valve problem.
take a look at the wash/drain solenoid (left side of pump).
To see if it is activating when it should not.
Up is wash down is drain.
If I remember the cycle for this unit correctly the unit should drain for a little while at the start of the cycle then the solenoid should move up and the unit should fill. The pump will be on but in a washing configuration. The fill valve should then shut off and the ubin should do the pre-wash (a few minutes). Then the drain solenoid is pulled down. It drains the solenoid then moves up and the unit fills again and does the full wash cycle. This should be half an hour or so. It then drains, the pump turns off and it dries the dishes.
The above is what I think it is bit I am not sure about this.
Your problem sounds like it is a timer problem.
Dirty dishes problem (Dishwasher Repair)
by cmeek711 3/1/2014 5:40:21 AM(UTC)
GE Profile dirty dishes and black specks (Dishwasher Repair)
by jaynoll80 2/28/2013 5:18:03 PM(UTC)
dirty dishes (Dishwasher Repair)
by ginger4683 11/5/2012 1:22:46 PM(UTC)
Dirty Dishes (Dishwasher Repair)
by makoa 1/15/2012 12:42:11 PM(UTC)
by gregrust 12/21/2011 3:11:45 PM(UTC)
Dishwasher Top Rack Dirty Dishes (Dishwasher Repair)
by jdh06 5/12/2011 4:31:02 PM(UTC)
dirty dishes/impeller (Washer Repair)
by winewino 4/23/2011 1:23:58 PM(UTC)
Dirty Dishes on bottom Rack (Dishwasher Repair)
by Derekclarke03 4/22/2011 6:29:08 AM(UTC)
Dirty dishes maytag dishwasher (Dishwasher Repair)
by goldbryant 4/11/2011 2:59:43 PM(UTC)
Frigidaire Dishwasher - top rack dirty dishes (Dishwasher Repair)
by officework13 3/15/2011 2:00:28 PM(UTC)
Dirty Dishes - Bosch Dishwasher (Dishwasher Repair)
by mcerods 1/22/2011 5:39:06 AM(UTC)
scummy and dirty dishes (Dishwasher Repair)
by jackofall? 1/16/2011 11:51:07 AM(UTC)
dirty dishes Maytag dishwasher (Dishwasher Repair)
by bobp0626 7/23/2010 3:18:50 PM(UTC)
Dirty Dishes-Whirlpool Gold Quiet partner III (Dishwasher Repair)
by kfitzpat9 3/30/2010 6:07:53 PM(UTC)
General fix for dirty dishes glasses upper rack (Dishwasher Repair)
by skylimit1959 9/29/2009 4:33:01 PM(UTC)
2 Pages12>
