cchase
#1 Posted : Saturday, January 14, 2012 4:25:49 PM(UTC)
cchase
Hello,
I just replaced the wax motor and uppercontrol board in the washer, which seems to have solved the draining issue, but on some cycles the door doesn't lock and the door lock light doesn't come on. When this happens it won't go into high spin. We've had some luck with stopping the machine and firmly resutting the door (sometimes pulling up, but it it still seems out of alignment.
Any suggestions ?
Also, we're wondering about the door lock cable - a solid plastic cable that goes from the door latch assemble to a corner of the liquid dispensor. This cable doesn't carry current or fluid. Is it critical somehow to the machine's operation, or just a trick to let the service man know you've been in there?
My email is cuillo@comcast.net
Thanks in advance
Chris
ApplianceJunk
#2 Posted : Sunday, January 15, 2012 10:44:40 AM(UTC)
ApplianceJunk
The cable is just there so you can pull on it to release the lock and open the door if it fails. I would guess your other problem maybe cause by the replacement wax motor not being installed correctly.
cchase
#3 Posted : Monday, January 16, 2012 11:50:46 AM(UTC)
cchase
On the door lock cable: I never would have figured that out.
I'll check the wax motor install. Pretty sure I got it right, but I'll make sure. The hinges on the door may have gotten a little sprung, but I'll make sure the door closes correctly.
Thanks again,
Chris
sidfink43
#4 Posted : Wednesday, January 18, 2012 4:33:12 PM(UTC)
sidfink43
That cable is what is used to open the door if the door lock fails.
I would check out the door lock mechanism and the wiring.
Chris (Washer Repair)
by CGLAZE 5/8/2013 1:53:19 PM(UTC)
chris p (Oven Repair (including Ranges and Cooktops))
by chris p 6/4/2012 8:02:25 PM(UTC)
Christmas Mess (Oven Repair (including Ranges and Cooktops))
by vicki beauchamp 1/8/2012 10:41:40 AM(UTC)
Chris (Refrigerator & Freezer Repair)
by Chris Cavanagh 7/18/2011 5:13:31 PM(UTC)
by chrisann21 6/16/2011 5:45:08 PM(UTC)
Oven Door Hinge Replacement - Christmas 5 days away! (Oven Repair (including Ranges and Cooktops))
by DDoukas 12/19/2010 4:24:23 PM(UTC)
by Chris A 7/19/2010 5:08:09 PM(UTC)
save christmas (Oven Repair (including Ranges and Cooktops))
by davidg.46 12/25/2009 5:01:22 AM(UTC)
Help! It's 3 Day Before Christmas And My Oven Is Self-destructing!! (Oven Repair (including Ranges and Cooktops))
by ljmom24 12/22/2009 12:20:41 PM(UTC)
chris (Dishwasher Repair)
by cleanslate 12/2/2009 5:29:18 PM(UTC)
christopherj (Washer Repair)
by christopherj 9/5/2009 6:07:17 AM(UTC)
by christopherj 9/5/2009 5:44:07 AM(UTC)
christinakendrick (Dryer Repair)
by christinakendrick 4/7/2009 4:37:42 PM(UTC)
by chrisdods9 2/4/2009 3:15:52 PM(UTC)
Christi (Refrigerator & Freezer Repair)
by CCURVIN 10/16/2008 1:45:39 PM(UTC)
