RSP3
#1 Posted : Friday, December 23, 2011 8:46:23 AM(UTC)
RSP3
My ice maker has stopped dumping ice. There is ice in the tray but the auger is not moving to dump it out. The ice maker part number is IMBD003-004. I removed it and let it thaw out and I replaced it. After 5 minutes it has not dispensed water again. How do I determine if it is the maker or something else inside?
ApplianceJunk
#2 Posted : Friday, December 23, 2011 9:12:26 AM(UTC)
ApplianceJunk
The first thing I check with any ice maker problem is that the freezer is cold enough. The freezer needs to be 0-5 deg. F to cycle correctly.
From what you have posted though I would say your problem is with the ice maker and it should be replaced.
The water valve would work or not work, I have never seen a intermittent water inlet valve and being it filled once before the valve is probably ok.
Just my 2 cents...
frigidaire ice maker 241642503 not working (Refrigerator & Freezer Repair)
by jesus freak 8/1/2023 3:07:31 PM(UTC)
Frigidaire ice maker and water dispenser not working (Refrigerator & Freezer Repair)
by goozpah 1/20/2023 6:39:18 AM(UTC)
Frigidaire Ice Maker Arm won't move (Refrigerator & Freezer Repair)
by Guest 7/10/2022 6:18:09 PM(UTC)
Frigidaire ice maker not working (Refrigerator & Freezer Repair)
by lilacreality 1/4/2016 1:38:29 PM(UTC)
Frigidaire Ice maker only making huge chunks (Refrigerator & Freezer Repair)
by WAKS 10/14/2015 6:46:20 PM(UTC)
frigidaire ice maker not working (Refrigerator & Freezer Repair)
by joeyjags 3/23/2015 10:39:43 AM(UTC)
Frigidaire Ice Maker Won't Turn Off (Refrigerator & Freezer Repair)
by Fathergoose007 9/7/2014 2:15:19 PM(UTC)
Frigidaire Ice Maker--making noise/not making ice (Refrigerator & Freezer Repair)
by lak 6/23/2013 3:03:35 PM(UTC)
Frigidaire Ice maker making ice very slow. (Refrigerator & Freezer Repair)
by Mrpaul88 7/27/2012 7:59:50 AM(UTC)
No water to Frigidaire ice maker. (Refrigerator & Freezer Repair)
by Ice Master 11/22/2011 8:59:04 AM(UTC)
Frigidaire Ice maker Valve not open (Refrigerator & Freezer Repair)
by jkor 5/20/2011 1:55:01 PM(UTC)
Frigidaire ice maker control panel has no power (Refrigerator & Freezer Repair)
by F1USGP 2/20/2011 2:15:22 PM(UTC)
Frigidaire ice maker switch shut off arm won't go down to on (Refrigerator & Freezer Repair)
by lcapelis 4/9/2010 1:31:50 AM(UTC)
by luigys22 2/22/2010 6:25:14 AM(UTC)
Frigidaire Ice Maker Won't Work; Water Dispenser OK (Refrigerator & Freezer Repair)
by chamounixalicat 2/18/2010 12:30:29 PM(UTC)
