marcousa
#1 Posted : Monday, February 16, 2009 2:05:50 PM(UTC)
marcousa
The Dryer run fine but never stops.
TechnicianBrian
#2 Posted : Monday, February 16, 2009 5:02:13 PM(UTC)
TechnicianBrian
If it never stops then your timer must not be advancing. Set it to a timed dry and remember where you set it. If you come back in 10 minutes and it hasn't moved, the timer is not advancing and thus will never stop the dryer.
#3 Posted : Tuesday, February 17, 2009 4:49:59 AM(UTC)
Try cleaning the moisture sensor bar
marcousa
#4 Posted : Wednesday, February 18, 2009 4:58:28 PM(UTC)
marcousa
I clean the moisture bar tryer not advancing
#5 Posted : Wednesday, February 18, 2009 6:12:47 PM(UTC)
Did you try timed dry mode as TechnicianBrian suggested
marcousa
#6 Posted : Thursday, February 19, 2009 2:26:03 PM(UTC)
marcousa
yes,I try timed dry mode and the Dryer run very good but never stop.
#7 Posted : Friday, February 20, 2009 2:24:50 AM(UTC)
Model MDE8400AYW
Sounds like the timer is not working.
Best way to check is with a meter.
With the unit unplugged, remove one of the timer motor leads from the timer and measure the motor for continuity. If it is open yopu need a new timer. This just checks for a blown motor. If OK put the wire back and do the next step.
Be careful the unit has 240 volts so is very dangerous.
While running check for voltage (120 volts AC) across the timer motor.
If it has voltage and is not advancing then the timer needs replacing.
Another way is if you can hear the timer running but it is not advancing, then the timer is shot.
Or you could just buy and install a new timer but this is a bit of a gamble.
Guest (4)
Dryer Repair Again and Again (Dryer Repair)
by Guest 6/25/2022 3:48:47 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Dryer repairs (Dryer Repair)
by P3FE 10/16/2021 2:36:49 PM(UTC)
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 3/19/2020 12:26:10 PM(UTC)
Dryer Repair Issue (Dryer Repair)
by jdharrin 10/2/2019 1:32:57 PM(UTC)
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 2/2/2018 5:35:41 PM(UTC)
Dryer repair Help! (Dryer Repair)
by Hah45 10/4/2017 2:39:32 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 12/26/2015 12:03:59 PM(UTC)
Dryer Repair (Dryer Repair)
by sotomargie 12/21/2015 9:44:35 AM(UTC)
Dryer repair (Dryer Repair)
by dchurch 9/26/2015 8:38:17 AM(UTC)
by jaybick 8/24/2015 6:34:15 AM(UTC)
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10/13/2014 10:54:09 AM(UTC)
by Tom Campion 4/14/2014 6:20:19 AM(UTC)
by kencorey281@gmail.com 11/12/2013 2:35:48 PM(UTC)
