IrmaE
#1 Posted : Thursday, November 15, 2007 11:25:57 AM(UTC)
IrmaE
My dryer will start and work for a while. Then it will shut off for again. After that it will start up again by itself and then shut off again. I took the back panel of and checked the heating element and it heats up. I also check the blower and it started up but after a couple of minutes the dryer turned off again. I need to know what else to check for and what part I need to buy.
IrmaE:confused:
#2 Posted : Friday, November 16, 2007 10:37:28 AM(UTC)
Your dryer probably has a Finish Guard future (page 13 in the "Use and care" manual).
IrmaE
#3 Posted : Saturday, November 17, 2007 9:53:46 PM(UTC)
IrmaE
Thank you for reply but when my dryer is on it is not on the finish guard cycle. It is on the regular cycle when it turns on and off. So what else could it be?
#4 Posted : Saturday, November 17, 2007 10:05:24 PM(UTC)
The Finish Guard is not a cycle. It is an option.
If your dryer does not have such option or you did not use it, then I have no idea what could have the dryer to restart by itself.
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
Whirlpool dryer---need to hold start button several seconds (Dryer Repair)
by pjlarivi 2/13/2021 10:44:25 AM(UTC)
