Hello,
I have a problem with my Kenmore model #665.15639000. The lights on the touch pad do not come on at all. I was told that there is a fuse i can replace. Is this true?
Thanks for your help!
Gregg
Hi Gregg, There is a thermal fuse which is located on the plastic frame of the control board. You have to remove the inner door panel in order to access it. Check the fuse for continuity and replace if it's open. - The part number for the thermal fuse is AP3115186Gene.
Thanks, Gene, I'll check it out.
Gregg
You are welcome, Gregg. Keep us posted.
