Sshawn_L
#1 Posted : Thursday, November 15, 2007 10:38:24 AM(UTC)
Sshawn_L
my dryer stopped working after i used it the night before i put a load in and let it run and went to sleep when i opened it in the morning it was hot inside but had not been running and i could see from inside the drum with the door open the element was glowing but the dryer wasent running, if i turn the knob to dry (nomatter what setting) i can see the element startglowing from inside the drum with the door open, but it dosent sound like its doing anything or move or make any noise, the light works when the door opens i dont know what is wrong and would appreciate any help i can get....also i noticed a while back i was drying a load and fell asleep and the trier never shut off but has been ok since
abbie
#2 Posted : Thursday, November 15, 2007 4:47:29 PM(UTC)
abbie
It Seem The Element Must Have Shorted To Ground May Need To Check Dryer Vent For Restrictions May Need New Element
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Front load dryer problem (Dryer Repair)
by Guest 4/29/2021 5:08:47 AM(UTC)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Dryer problem (Dryer Repair)
by johnh@echoetching.com 3/27/2018 12:50:30 PM(UTC)
by al kopsick 10/8/2017 11:08:40 AM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
Dryer Problem (Dryer Repair)
Belarus clcw199 11/5/2015 9:07:48 AM(UTC)
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 10/19/2015 9:06:20 AM(UTC)
by gtravis331 4/13/2014 6:01:38 PM(UTC)
by Qzzy 3/17/2014 8:01:45 PM(UTC)
clothes dryer problem (Dryer Repair)
by jsullivan652 1/28/2014 1:20:49 AM(UTC)
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 10/22/2013 3:21:12 AM(UTC)
by Pat Ranguette 8/26/2013 5:41:29 PM(UTC)
by forenz 7/2/2013 1:34:33 PM(UTC)
by Hoovdawg3 6/8/2013 3:42:16 PM(UTC)
