#1 Posted : Monday, February 9, 2009 10:48:51 AM(UTC)
If a lid switch is bad can that be the reason why the water in the washer will not drain:confused:
#2 Posted : Monday, February 9, 2009 1:03:55 PM(UTC)
If a lid switch is bad, then there would not be power to the motor. Lid switch is a safety devise.
#3 Posted : Monday, February 9, 2009 1:45:33 PM(UTC)
thanks gene your the man
#4 Posted : Monday, February 9, 2009 3:15:14 PM(UTC)
You are welcome.
#5 Posted : Monday, February 9, 2009 3:39:05 PM(UTC)
Gene would you happen to know if a gas dryer model# dbxr463gd2ww
has a thermo-fuse or are thermo-fuses located on certain models.
And if so where can I find it on this model, also I'm interested getting certified in appliance do you have any advice or references for any classes thanks again
#6 Posted : Monday, February 9, 2009 4:08:15 PM(UTC)
Usually such devises are located on or around a blower housing or an air ducts. In GE dryers you can find them also on or around heat deflectors and/or diffusers.
I'm not sure about education. You have to check it with local people. Most common education is "in field".
#7 Posted : Monday, February 9, 2009 4:09:56 PM(UTC)
thanks again
Guest (6)
washer water not draining (Washer Repair)
by mwashbu 10/21/2019 2:14:42 PM(UTC)
Water not draining (Washer Repair)
by macismom 2/28/2014 2:40:48 PM(UTC)
by kyarbrough5@cox.net 7/15/2012 5:04:08 PM(UTC)
water not draining (Dishwasher Repair)
by dsbowler 7/9/2012 9:19:24 AM(UTC)
by hillestad 12/29/2011 9:09:22 PM(UTC)
Came home to burnt rubber smell and water not draining from Washer (Washer Repair)
by kota701 12/8/2011 11:27:57 AM(UTC)
Water not Draining (Washer Repair)
by ccino1 10/26/2011 7:38:45 PM(UTC)
Water not draining after new pump was installed (Dishwasher Repair)
by lloyd520 12/29/2010 4:44:42 PM(UTC)
water not draining completely (Dishwasher Repair)
by ronmer 5/5/2010 6:51:43 AM(UTC)
Water not draining (Dishwasher Repair)
by mrmrst 4/21/2009 10:24:22 AM(UTC)
Washer water not draining from rinse cycle (Washer Repair)
by Michaele 11/24/2008 3:21:47 AM(UTC)
