Larrybackman
#1 Posted : Monday, December 5, 2011 3:21:39 PM(UTC)
Larrybackman
I have an 8-10 year old Maytag washer that isn't washing as good as it use to. I took a look and see that the agitator is no longer seated in place. The agitator just rises up as the load continues. I haven't replaced anything yet. I have attached some pictures and cannot locate the serial or model #. Looking to find out if its the agitaor or some other issue.
Larrybackman attached the following image(s):
Larrybackman
#2 Posted : Monday, December 5, 2011 3:33:07 PM(UTC)
Larrybackman
I found the Model and SN:
Model PAV336OAWW
Rev: 17
SN 17215742AX
#3 Posted : Tuesday, December 6, 2011 5:31:29 AM(UTC)
Replacement parts for MAYTAG PAV3360AWW WASHER-TOP LOADING | AppliancePartsPros.com
I believe that the bolt Item 4 in Section 9 should hold it down.
Larrybackman
#4 Posted : Saturday, December 10, 2011 12:48:11 PM(UTC)
Larrybackman
Originally Posted by: denman Go to Quoted Post
I took a closer look and the bolt is still intact. It appears as if the middle and upper assembly has come loose off the base. I can put the middle/upper assembly onto the base but it is not snug and will rise and not agitate the way it's suppose to. I'd like to order what I need today or Sunday along with a dryer order.
Larrybackman
#5 Posted : Saturday, December 10, 2011 3:04:49 PM(UTC)
Larrybackman
So do I need the base as well as the middle?
#6 Posted : Sunday, December 11, 2011 3:59:32 AM(UTC)
Take a look in the parts Item 1 in section 9.
Click on the picture and a new page will open with more views and a Q&A section.
I would replace both.
Also if the bolt is rusted replace it.
Maytag Washer agitator slipping (Washer Repair)
by Waywardson 4/4/2019 7:45:47 AM(UTC)
Older Maytag Washer Agitator Removal (Washer Repair)
by rjhornak 4/20/2012 10:40:17 AM(UTC)
Maytag Washer agitator not spining (Washer Repair)
by neupur5 2/25/2012 10:08:36 AM(UTC)
Maytag washer agitator spin is weak or non-existant (Washer Repair)
by tsbruers 6/1/2010 6:30:41 PM(UTC)
Maytag Washer agitator not working (Washer Repair)
by Needhelpnow 12/30/2009 9:38:38 AM(UTC)
