gypsyqueen
#1 Posted : Thursday, February 5, 2009 6:44:09 AM(UTC)
gypsyqueen
Great dryer that I have never had a problem with suddenly in the middle of laundry day quit heating. Should I replace element or is there something else I should check first. Yes, I am a female but I do know my way around the toolbox as long as it is not too high tech.:D Thanks, Morgan
magician59
#2 Posted : Thursday, February 5, 2009 8:20:28 AM(UTC)
magician59
Heating elements don't burn out as frequently as the failure of other components. Best to check for continuity in the thermal fuse and the thermostats first. Before you get inside the dryer, though, try flipping the breaker off and on a few times to make sure it isn't partially tripped. If everything else is good, then check for continuity on the element. Any component that is electrically open needs to be replaced.
gypsyqueen
#3 Posted : Thursday, February 5, 2009 4:52:36 PM(UTC)
gypsyqueen
How do I check these items you are talking about? I have a meter for checking to see if there is power in an outlet, would that be what I use? And how do I know where the objects are located because I do not have a manual.Damn, sorry..I got ahead of myself, first and foremost I thank you for your help and apologize for asking sooo many questions. I am eager to learn how to fix this and I have forgotten my manners. Morgan
#4 Posted : Friday, February 6, 2009 5:25:09 PM(UTC)
Hi Morgan,
You need a simple ohmmeter to check a few parts for continuity, but the first thing I would do is check the circuit breakers for the dryer to make sure there is 240 VAC at the power outlet.
You can find the complete troubleshooting instructions in one of our previous posts: http://forum.appliancepartspros...timer-wont-turn-off.html
The parts reference numbers posted there are different with your model, but you can find them through the break down diagrams for the Roper dryer Model REL4632BW2
Good luck.
gypsyqueen
#5 Posted : Sunday, February 8, 2009 11:25:02 AM(UTC)
gypsyqueen
Thank you for the info! I do not have a meter like those in the instructions but I did have a continuity tester. The circuit,fuse and thermostats checked out fine but there was no continuity with the thermal cut-off or the heating element. Does that mean that they are both out?
#6 Posted : Monday, February 9, 2009 12:19:48 PM(UTC)
If the continuity test shows an open circuit that means a bad part. In your case it means the heating element and the thermal cut-off are bad and have to be replaced.
gypsyqueen
#7 Posted : Monday, February 9, 2009 4:08:47 PM(UTC)
gypsyqueen
Thank you Gene! I will let you know how it goes after I receive said parts.Thanks again for your help,
Morgan
#8 Posted : Monday, February 9, 2009 4:12:06 PM(UTC)
gypsyqueen
#9 Posted : Tuesday, March 3, 2009 11:13:39 AM(UTC)
gypsyqueen
Thank you Gene for all your help!!!! My dryer is running as good as new now and I appreciate all the help you provided! :D
#10 Posted : Tuesday, March 3, 2009 2:09:53 PM(UTC)
I'm glad you were able to fix it.
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 6/11/2021 11:46:23 AM(UTC)
Kenmore Dryer stopped heating. (Dryer Repair)
by willow5000 9/24/2014 1:48:01 PM(UTC)
Whirlpool Dryer stopped heating (Dryer Repair)
by jambla 8/19/2014 12:27:22 PM(UTC)
by jrnutpaul 9/20/2013 8:31:58 AM(UTC)
dryer stopped heating and runs non stop (Dryer Repair)
by jescousa 2/26/2013 8:30:05 AM(UTC)
Dryer Stopped Heating Up (Dryer Repair)
by rrblk 10/8/2011 4:12:13 PM(UTC)
Whirlpool Estate Dryer Stopped Heating (Dryer Repair)
by kimyoung 5/16/2011 8:58:46 AM(UTC)
GE dryer stopped heating but dryer still works (Dryer Repair)
by picker1 4/6/2011 6:53:41 AM(UTC)
Help...my dryer stopped heating (Dryer Repair)
by BDGD 12/3/2010 12:47:30 PM(UTC)
by Tcon 10/17/2010 6:22:21 AM(UTC)
by jstayoung1 6/10/2010 12:37:53 AM(UTC)
by jstayoung1 6/10/2010 12:21:32 AM(UTC)
by atciskanik 3/3/2010 4:32:59 AM(UTC)
whirlpool gas dryer stopped heating what could be the problem (Dryer Repair)
by Lacey14 1/18/2010 5:39:07 AM(UTC)
Admiral Dryer Stopped Heating. Why? (Dryer Repair)
by kelso1 9/5/2009 7:33:29 AM(UTC)
