The display (clock, temp, etc.) vanished when the oven was turned on, reappeared when the oven was off, and then disappeared altogether. The oven still works well. The range is a gas range with an electric oven.
The complete troubleshooting instructions you can find in the service manual. To help you with the right part numbers I need the rest of the model number. Gene.
Could be something as simple as a bad connection on the clock.
Originally Posted by: edouard thai  The display (clock, temp, etc.) vanished when the oven was turned on, reappeared when the oven was off, and then disappeared altogether. The oven still works well. The range is a gas range with an electric oven. Thank you for the answers, Gene and Appliancejunk. Where do I find the model number on the appliance ? I foiund the number 8114P527-60 on the inside of the oven door on the lower left side of the oven door below the 800 phone number. I got the svd 48600 number from the manual. Than you for your help.
