ldorata
#1 Posted : Tuesday, April 26, 2011 12:41:14 PM(UTC)
ldorata
My stove and oven are working, however, the control panel does not display anything (temperature, etc.) when I press "Bake" for example. It remains blank. The oven goes on when I depress the bake key and then the start key, but nothing shows. I called and discussed it with a troubleshooter and it was suggested that it was just a fuse. When I called for a part, I was told that the "Thermostat Fix" AP3853531 is the part that I need. I do not want to order it unless this is correct. Any idea?
Joe / APP Team
#2 Posted : Tuesday, April 26, 2011 1:54:54 PM(UTC)
Joe / APP Team
Idorata,
I don't think your problem would be any bimetal thermostat, if it was, the unit would be "dead" or would have no heat, since evrything works except the display, You should probably start at the display board. Based on you description.
Part number: AP3176181
Good Luck,
Control panel display very dim (Oven Repair (including Ranges and Cooktops))
by wgfwli 5/25/2015 7:02:05 PM(UTC)
Control Panel display stuck (Refrigerator & Freezer Repair)
by Rdeal 8/15/2012 1:05:49 PM(UTC)
Control Panel Display Malfunction (Oven Repair (including Ranges and Cooktops))
by crash365 12/23/2011 9:29:23 AM(UTC)
Control panel display garbled (Oven Repair (including Ranges and Cooktops))
by tmaher22 11/29/2011 10:32:02 AM(UTC)
Amana Gas Range Control Panel Display (Oven Repair (including Ranges and Cooktops))
by jose2741 6/17/2011 4:36:32 AM(UTC)
Blank GE control panel display (Oven Repair (including Ranges and Cooktops))
by jelchin 4/21/2011 2:32:09 PM(UTC)
Control Panel Display Not Lit (Dishwasher Repair)
by Bhedman 1/1/2011 9:03:00 AM(UTC)
Control panel displays OFF (Oven Repair (including Ranges and Cooktops))
by mosc2 7/9/2009 6:38:56 AM(UTC)
by edouard thai 11/14/2007 1:23:00 PM(UTC)
