Hi, I have a kitchen Aid ykgst307hs8 gas stove and the display has stopped working. The stove works fine and I can still use it by simply listening to the beeps. Do I need to replace the entire control panel or is there a fuse for the display?
Many thanks, :confused:
Your model has a microcomputer and a control board. You would need to see if you are getting voltage to the board the display is on.
There is no fuse that I know of.
