2 Pages<12
libertyappl
#11 Posted : Thursday, October 2, 2008 8:34:26 AM(UTC)
libertyappl
budney,
If it's a whirling sound check all the little holes inside the tub for anything that may be stuck in a hole(like a nail, screw, bra wire, etc....)
You will probably want to use a flash light to look. May get lucky and that's all it is.
Nat
chengsr
#12 Posted : Monday, February 2, 2009 10:29:59 AM(UTC)
chengsr
I had the tub replaced 3 years ago and lately during the final spin cycle a loud noise occurs and only during the final spin cycle. Is it possible that the strut is going bad?
#13 Posted : Monday, February 2, 2009 1:47:12 PM(UTC)
Is it a bearing noise, or a thumping sound.
chengsr
#14 Posted : Monday, February 2, 2009 5:05:55 PM(UTC)
chengsr
It starts with a 2 or 3 thump and then it turns into a bearing noise, I guess I answer my own question?
#15 Posted : Tuesday, February 3, 2009 12:32:25 AM(UTC)
I would pull the bottom front panel and check for a busted shock. Also, if you have an amprobe, check the total current into the washer at the power plug.
If the current draw in high speed spin is getting near 3 amps, your speed control board/motor will fail soon with continued running.
chengsr
#16 Posted : Tuesday, February 3, 2009 5:27:59 AM(UTC)
chengsr
Thanks, I had the inner tub, motor and motor controlbroard replace 3 years ago just wondering if there is any warranty on Magtag OEM parts.
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
2 Pages<12
