jjenks22
#1 Posted : Friday, November 25, 2011 4:33:37 PM(UTC)
jjenks22
I have a Calypso washer that is leaking about a cup of water out from underneath every cycle. I took off the front and ran it through the cycle to determine the cause. None of the hoses are leaking. The leak is originating from the left bottom of the tub directly between the stabilizers from a small welded joint on the frame that holds the tub. I see no evidence that it is coming from the top so I assume the bottom of the tub or a seal is compromised. Which is it likely to be and what is an approximate cost to repair? Has apparently been leaking for some time since the bottom is now rusted through in one spot.
sidfink43
#2 Posted : Saturday, November 26, 2011 6:18:08 PM(UTC)
sidfink43
It is hard to say what needs to be replaced without being there, but these are not the greatest machines in the world (they are very good when the work, not good when the have problems which unfortunately is the case many times). Given it 10+ years it is ready to be replaced.
stubborn tub nut, leaking tub, loud noise (Washer Repair)
by stubborn nut 10/24/2014 5:14:20 PM(UTC)
Leaking Tub Seal (Washer Repair)
by randyowens 2/8/2014 11:14:55 AM(UTC)
Any way to re-seal leaking tub on Frigidaire Affinity washer (Washer Repair)
by curious14 7/17/2013 5:59:30 PM(UTC)
leaking tub (Washer Repair)
by thesulman 8/8/2010 9:27:02 AM(UTC)
Leaking Tub (Washer Repair)
by mikejohnston5 1/12/2010 7:48:15 AM(UTC)
Leaking tub seal but have no model number can anybody help (Washer Repair)
by dirtclaud007 9/13/2009 6:48:03 PM(UTC)
Frigidaire Stackable W/D, leaking tub seal (Washer Repair)
by FDAR 7/9/2009 11:48:13 AM(UTC)
Leaking tub seal/bearing (Washer Repair)
by Mike Luke 10/9/2007 5:05:34 PM(UTC)
