thesulman
#1 Posted : Sunday, August 8, 2010 9:27:02 AM(UTC)
thesulman
the tub leaks at the top of it when the water setting is on high water. Is the seal at the top supposed to be water tight. or could it be over filling?
thanks Sully
Model #wsm2700dawww
#2 Posted : Sunday, August 8, 2010 11:27:21 AM(UTC)
Is the water level near the top of the tub when it fills up, like less than an inch from overflowing?
thesulman
#3 Posted : Tuesday, August 10, 2010 5:20:17 AM(UTC)
thesulman
Rich the water level when filled is at least 2" below the top.
thanks Sully
#4 Posted : Tuesday, August 10, 2010 8:15:14 AM(UTC)
That's too high. Pull the plastic hose off the water level switch and blow in it, might be soap residue partially blocking the bottom of it.
If still a problem, replace the water level switch.
stubborn tub nut, leaking tub, loud noise (Washer Repair)
by stubborn nut 10/24/2014 5:14:20 PM(UTC)
Leaking Tub Seal (Washer Repair)
by randyowens 2/8/2014 11:14:55 AM(UTC)
Any way to re-seal leaking tub on Frigidaire Affinity washer (Washer Repair)
by curious14 7/17/2013 5:59:30 PM(UTC)
Leaking tub (Washer Repair)
by jjenks22 11/25/2011 4:33:37 PM(UTC)
Leaking Tub (Washer Repair)
by mikejohnston5 1/12/2010 7:48:15 AM(UTC)
Leaking tub seal but have no model number can anybody help (Washer Repair)
by dirtclaud007 9/13/2009 6:48:03 PM(UTC)
Frigidaire Stackable W/D, leaking tub seal (Washer Repair)
by FDAR 7/9/2009 11:48:13 AM(UTC)
Leaking tub seal/bearing (Washer Repair)
by Mike Luke 10/9/2007 5:05:34 PM(UTC)
