Gary Hibbert
#1 Posted : Saturday, January 31, 2009 7:27:19 AM(UTC)
Gary Hibbert
My electric dryer is does not heating up. I have checked the circuit breaker and they are not tripped. I have also unpluged it for 24 hrs and still no heat.
kayakcrzy
#2 Posted : Sunday, February 1, 2009 4:12:42 AM(UTC)
kayakcrzy
gary, it is either the element or the thermal fuse, mounted on the top left side of the element housing. if you have a ohm meter, unplug the dryer, and ohm it out. make sure you pull the wires off of either part when you ohm it out. tom [url=]applianceeducator.com - parts[/url]
#3 Posted : Sunday, February 1, 2009 5:23:27 AM(UTC)
When you checked your breaker did you just look at it or did you turn it off then back on. Often if you loose half the line it will not trip the breaker.
Best way is to check with a meter to ensure you have 240 volts.
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
