mikflanigan21
#1 Posted : Thursday, January 29, 2009 11:14:16 AM(UTC)
mikflanigan21
My dishwasher continues to fill without any cycles selected. I have turned off the power to the dishwater and the water still continues to fill at a fast rate. The only way to stop the water is to turn it off at the shut off valve located on the water lines.
Any ideas of where i should start trouble shooting.
Thanks for any help.
#2 Posted : Thursday, January 29, 2009 1:34:24 PM(UTC)
Model DU941PWKB1
Remove the kick panel.
Remove the connector from the water valve, Item 16 in the "Tub Assembly" section.
Turn the water back on.
If it starts to fill with the door open then you know the valve is shot as it should be closed with no power to it.
Note: It may not start to fill, this does not mean the valve is OK because you have removed the water pressure from it and this may have let it close.
So if it does not fill, reattach the connector to the valve and with the water on start a cycle. Then open the door, it should stop filling immediately. If not the valve is shot.
Only other thing it could be is if something weird is happening and it is getting power with the door open. The door switches normally kill power to the entire dishwasher.
Whirlpool Quiet Partner II Repair (Dishwasher Repair)
by Scubacrazy56 3/1/2024 7:54:50 AM(UTC)
Need replacement control panel for Whirlpool Quiet Partner III (Dishwasher Repair)
by teewhile 1/18/2022 6:59:40 PM(UTC)
Whirlpool Quiet Partner II DU1145 (Dishwasher Repair)
by Guest 3/25/2021 6:39:10 PM(UTC)
Whirlpool Quiet Partner III GU2400XTPS6 on but only runs the drain pump (Dishwasher Repair)
by misterbrokeit 10/31/2020 1:14:40 PM(UTC)
Whirlpool Quiet PArtner III leaking underneath (Dishwasher Repair)
by KareeHunt 8/26/2020 8:26:37 AM(UTC)
Whirlpool Quiet Partner II Model DU1055XTVQ8 (Dishwasher Repair)
by mgandhd 4/29/2020 9:16:12 AM(UTC)
Whirlpool Quiet Partner iii stuck in wash cycle (Dishwasher Repair)
by WaltP 4/19/2020 9:47:42 AM(UTC)
Whirlpool Quiet Partner II (Dishwasher Repair)
by dresstheman 12/30/2017 5:17:12 PM(UTC)
Whirlpool Quiet PArtner III Pot/Pan light on and dishwasher will not run (Dishwasher Repair)
by DJ Chaffers 1/2/2016 6:13:21 PM(UTC)
Whirlpool quiet partner ii won't start (Dishwasher Repair)
by Mac m 1/6/2015 5:53:21 PM(UTC)
Whirlpool Quiet Partner ii no start (Dishwasher Repair)
by captian23 12/20/2014 6:26:48 PM(UTC)
Whirlpool Quiet Partner III gets stuck on a Normal cycle (Dishwasher Repair)
by jessman1128 10/27/2014 9:09:10 PM(UTC)
Whirlpool Quiet Partner III help (Dishwasher Repair)
by sjde 9/10/2014 4:42:56 PM(UTC)
Whirlpool Quiet Partner III - Door is loose; drops quickly; doesn't stay down (Dishwasher Repair)
by ESticker 7/2/2014 4:11:59 PM(UTC)
by mgmills 6/8/2014 7:58:45 AM(UTC)
