2 Pages12>
RyanCasey
#1 Posted : Sunday, January 25, 2009 7:39:59 PM(UTC)
RyanCasey
I have a defrost issue with my GE gsl22jfpbs. I want to test the defrost timer but cannot locate it. Does this model have a defrost timer or an adaptive defrost module? I have tried searching your wessite for my model number but have found no matching threads.
Thank you.
Ryan
#2 Posted : Tuesday, January 27, 2009 7:13:11 AM(UTC)
Am not sure if the following is the same as yours but it may be close or perhaps some of the info will apply .
http://appliancejunk.com...refrigerator/31-9072.pdf
Check under the unit behind the kick plate for the tech sheet that applies to this unit.
RyanCasey
#3 Posted : Tuesday, January 27, 2009 7:39:07 PM(UTC)
RyanCasey
Thank you for your response. This is the service manual for models with digital temp displays. My model has manual temperature control knobs. Otherwise everything looks pretty much the same. However, how do I run diagnostic tests with manual control knobs? Also, there was no tech sheet behind the kick plate.
#4 Posted : Wednesday, January 28, 2009 3:33:54 AM(UTC)
Sorry do not know how to do this.
On some GE's there is a wire that has to be swapped on the Control Board.
On some you cannot force a defrost.
Hopefully someone will jump in who has experience on this Model
Getting info on many GE's is next to impossible.
I think your unit uses a glass type defrost heater, you may want to start with it as they are a known problem.
Many units originally had a single heater and now require a double heater kit.
The single elements were burning out too often.
RyanCasey
#5 Posted : Thursday, January 29, 2009 8:45:34 AM(UTC)
RyanCasey
Thanks for your replies. I'll try replacing the defrost heater and thermostat, maybe that will do the trick. Any idea what those two items should cost me?
#6 Posted : Thursday, January 29, 2009 9:44:59 AM(UTC)
If you do not have a meter to check the heater at least take a look at it, often you can see where it has burned out.
Heater
Part Details - GE HEATER HARNESS DEF, part number: WR51X10101
Is the new 2 element type
Thermostat
Part Details - GE THERMOSTAT DEF, part number: WR50X10068
You may need a couple wire nuts and some silicone sealant or equivalent to install the thermostat. This is if you have to cut the wires to install it. Use the wire nuts and the seal tthe open ends. Also I like to face the open end down so any water from derfost cannot enter the wire nuts.
Give them a call because some of the heater kits include a thermostat. I am not sure about this one.
RyanCasey
#7 Posted : Thursday, January 29, 2009 1:13:32 PM(UTC)
RyanCasey
I ordered the parts from the GE website. The assembly comes with a t-stat and a temp sensor. Total price with shipping and taxes was approx $80. I'll let you know how it goes. Your help has been much appreciated.
RyanCasey
#8 Posted : Thursday, January 29, 2009 1:18:52 PM(UTC)
RyanCasey
Another quick question... If I take out the "faulty" heater now while I wait a few days for the new one to arrive, will the freezer still run with the heater disconnected?
#9 Posted : Thursday, January 29, 2009 2:17:39 PM(UTC)
Yes it should.
It will take a few days for the evaporator coils to ice up again and stop the cooling.
This of coarse depends on how often you open the doors.
RyanCasey
#10 Posted : Thursday, January 29, 2009 4:04:48 PM(UTC)
RyanCasey
I just removed the heater. The coils are totally burned out. I am sure now, that it was the problem. I'll give you an update after the parts arrive. Thanks.
How much do you think I saved by not calling a repair man?
Guest (10)
Whirlpool upright freezer defrost timer location (Refrigerator & Freezer Repair)
by georgerose 9/6/2014 6:49:53 AM(UTC)
Whirlpool defrost timer location? (Refrigerator & Freezer Repair)
by TomD62 4/20/2014 7:00:06 PM(UTC)
Defrost Timer Location (Refrigerator & Freezer Repair)
by Beowulf 10/4/2013 4:55:49 AM(UTC)
Kenmore Defrost Timer Location (Refrigerator & Freezer Repair)
by frigadare 10/2/2012 9:58:24 AM(UTC)
Admiral Defrost Timer Location (Refrigerator & Freezer Repair)
by alshadow 10/3/2011 6:34:56 PM(UTC)
by aaron bremiller 6/17/2011 8:33:35 AM(UTC)
Defrost timer location (Refrigerator & Freezer Repair)
by WayneW 7/12/2010 12:13:32 PM(UTC)
Defrost Timer Location & Part Number (Refrigerator & Freezer Repair)
by ptisteve 6/29/2010 11:38:25 PM(UTC)
Defrost Timer location (Refrigerator & Freezer Repair)
by manhhung29 5/3/2010 4:39:21 PM(UTC)
by bobo123 2/14/2010 2:11:50 PM(UTC)
defrost timer location for older Kenmore (Refrigerator & Freezer Repair)
by jeff92rs 7/29/2009 9:26:35 AM(UTC)
Not defrosting - need defrost timer location, icemaker remove/reinstall info (Refrigerator & Freezer Repair)
by LeeHamilton 7/20/2009 2:05:53 PM(UTC)
by Orlando54 7/9/2009 6:38:50 AM(UTC)
Defrost Timer locations (Refrigerator & Freezer Repair)
by EamonAidanAlexa 5/26/2009 8:28:56 AM(UTC)
Frigidaire defrost timer location? (Refrigerator & Freezer Repair)
by jlanza 1/17/2009 1:26:14 PM(UTC)
2 Pages12>
