I read several posts and followed suggestions to check. It seems to do with defrost timer. When I pressed on the switch with the freezer door open, the freezer fan was still running. But if I did the same for the other door (refrigerator), the fan stopped. The problem for me is I can not locate the defrost timer. I opened the lower end in the back and found only condenser and compressor. I also tried to open the panel covering the coil and found nothing. Could you help me locate where the defrost timer is.
Thanks, Joe
But I'm still not sure where it is
