manhhung29
#1 Posted : Monday, May 3, 2010 4:39:21 PM(UTC)
manhhung29
I read several posts and followed suggestions to check. It seems to do with defrost timer. When I pressed on the switch with the freezer door open, the freezer fan was still running. But if I did the same for the other door (refrigerator), the fan stopped. The problem for me is I can not locate the defrost timer. I opened the lower end in the back and found only condenser and compressor. I also tried to open the panel covering the coil and found nothing. Could you help me locate where the defrost timer is.
Thanks,
Joe
manhhung29
#2 Posted : Monday, May 3, 2010 6:09:02 PM(UTC)
manhhung29
But I'm still not sure where it is
Whirlpool upright freezer defrost timer location (Refrigerator & Freezer Repair)
by georgerose 9/6/2014 6:49:53 AM(UTC)
Whirlpool defrost timer location? (Refrigerator & Freezer Repair)
by TomD62 4/20/2014 7:00:06 PM(UTC)
Defrost Timer Location (Refrigerator & Freezer Repair)
by Beowulf 10/4/2013 4:55:49 AM(UTC)
Kenmore Defrost Timer Location (Refrigerator & Freezer Repair)
by frigadare 10/2/2012 9:58:24 AM(UTC)
Admiral Defrost Timer Location (Refrigerator & Freezer Repair)
by alshadow 10/3/2011 6:34:56 PM(UTC)
by aaron bremiller 6/17/2011 8:33:35 AM(UTC)
Defrost timer location (Refrigerator & Freezer Repair)
by WayneW 7/12/2010 12:13:32 PM(UTC)
Defrost Timer Location & Part Number (Refrigerator & Freezer Repair)
by ptisteve 6/29/2010 11:38:25 PM(UTC)
by bobo123 2/14/2010 2:11:50 PM(UTC)
defrost timer location for older Kenmore (Refrigerator & Freezer Repair)
by jeff92rs 7/29/2009 9:26:35 AM(UTC)
Not defrosting - need defrost timer location, icemaker remove/reinstall info (Refrigerator & Freezer Repair)
by LeeHamilton 7/20/2009 2:05:53 PM(UTC)
by Orlando54 7/9/2009 6:38:50 AM(UTC)
Defrost Timer locations (Refrigerator & Freezer Repair)
by EamonAidanAlexa 5/26/2009 8:28:56 AM(UTC)
by RyanCasey 1/25/2009 7:39:59 PM(UTC)
Frigidaire defrost timer location? (Refrigerator & Freezer Repair)
by jlanza 1/17/2009 1:26:14 PM(UTC)
