2 Pages12>
Mike Rometer
#1 Posted : Sunday, November 13, 2011 7:47:02 AM(UTC)
Mike Rometer
:confused: received control panel part; washer flashing & not working, just over 1 year old; replacement control panel looks wrong--where is the circuit board panel? mine only came with the outer cover face and a plug; no circuit board as I see on old washer? what gives? is it supposed to come with circuit board too? thanks
Jaronbaer
#2 Posted : Tuesday, November 15, 2011 12:45:30 AM(UTC)
Jaronbaer
1 Year Warranty and Same Day Dispatch On Ray Ban Sunglasses.Discounts on Ray Ban!Sign up today for Instant Access.Cheap Ray Ban on ******** for less. Cheap ray ban. Bid now! Buy Save on Wholesale Ray-Ban Find NexTag Sellers' Lowest Price! And Save Big Designer Closeout Sales Buy Direct from China Factories. Sale Prices Latest Fashions and Styles on Sale Name Brands on Sale!
#3 Posted : Tuesday, November 15, 2011 2:57:49 AM(UTC)
I cannot find any info on the given model number.
Tried AppliancePartsPros and the Whirlpool sites.
Please check it.
Also what are the part number/s that you ordered.
Mike Rometer
#4 Posted : Tuesday, November 15, 2011 4:53:13 AM(UTC)
Mike Rometer
part sent me was Whirlpool W10250016; it was recommended & ordered during a live chat I had with technician after I checked & gave the washer model #; any help would be appreciated--thanks
model # i'm reading is right off the warranty card---KUDS30IVWH4;
#5 Posted : Wednesday, November 16, 2011 6:50:45 AM(UTC)
Here are your parts.
I could not find a VWH4 so the following is a VWH3 they are probably the same.
Replacement parts for WHIRLPOOL KUDS30IVWH3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
W10250016 is the Panel Ctrl (control panel).
It should be basically the keyboard.
The hosing with the keyboard installed and a ribbon cable coming out of the keyboard which plugs into the control board.
If you want the Control Board then it is AP4564002.
donna lehmer
#6 Posted : Wednesday, November 16, 2011 7:17:48 AM(UTC)
donna lehmer
f21 is the code on my washer want drain hose noy kinked or stoped up i dont know what part to get help
Mike Rometer
#7 Posted : Friday, November 18, 2011 5:06:55 AM(UTC)
Mike Rometer
ok--thanks--
how does one tell what part is bad? i guess plug & play will tell, right? do you buy both panel & keyboard to be safe? first time with your guidance- existing one looks like keyboard plugs in back of control board & board looks semi-fixed in place withbracket-like tabs; does not look like a simple snap-in removable setup; any hints? thanks! (getting close to holiday dishes and panicking):(
#8 Posted : Saturday, November 19, 2011 2:05:12 AM(UTC)
[COLOR="DarkRed"]how does one tell what part is bad? i guess plug & play will tell, right?[/COLOR]
The usual way to troubleshoot theses parts is to disconnect the keypad (panel) from the control board and then check the keys at the ribbon cable with a meter. If it checks out OK then replace the control board first.
Still a bit of a crap shoot but your odds are better.
Sometimes the following works for bad keys or no keys.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
I have been trying to upload the tech sheet to you but it fails. Could be a problem with this site, I will try again later today.
In any case it is usually taped to the back of the kick plate.
Sorry I do not follow the second part of your post.
On many units the board just snaps onto the front panel. Some units also have screw/s. If it is snapped on just be gentle as yuou do not want to break the snaps.
#9 Posted : Saturday, November 19, 2011 3:47:41 AM(UTC)
Well I have been able to attach files to other posts but cannot add an attachment to yours.
have tried several times with different file downloads without success.
So hopefully the tech sheet is under the unit.
Mike Rometer
#10 Posted : Saturday, November 19, 2011 5:53:15 AM(UTC)
Mike Rometer
thanks for the time & info, denman--really appreciate it; feeling a little better with your info & with a forum out there to help; we will give it a try; pre-holiday panic and local fix guy wants lots of $$$ just to visit; sometimes think the old mechanical switches on things were less hassle; thanks again! oh--what about stuff like Noalox (joint compound for electrical?) to put in wire plugs to keep out moisture? advised? thanks--
Guest (7)
Main Control Board Replacement Part for LG Dishwasher (Dishwasher Repair)
by TavisTr0n 9/22/2014 7:56:49 PM(UTC)
Whirlpool Cabrio dryer control board replacement (Dryer Repair)
by JTR1970 11/15/2013 3:25:51 PM(UTC)
Dishwasher Control Board Replacement (Dishwasher Repair)
by JimStinson 8/11/2013 4:19:15 AM(UTC)
Control board replacement (Oven Repair (including Ranges and Cooktops))
by mark330038 7/10/2013 3:42:47 PM(UTC)
Frigidaire Dryer Control Board Replacement (Dryer Repair)
by barb1948 6/22/2013 10:39:49 AM(UTC)
Whirlpool RBD305PDQ11 control board replacement (Oven Repair (including Ranges and Cooktops))
by horn 10/29/2012 7:48:38 PM(UTC)
Whirlpool Double Oven Control Board Replacement (Oven Repair (including Ranges and Cooktops))
by destan 7/18/2011 8:10:06 AM(UTC)
by dianeandjosh 11/14/2010 12:19:58 PM(UTC)
Electric control board replacement (Oven Repair (including Ranges and Cooktops))
by mthompson 1/27/2010 7:08:18 AM(UTC)
Control Board Replacement??? (Washer Repair)
by suzim424 9/9/2009 4:02:55 AM(UTC)
Kitchen Aid Control Board Replacement Help (Microwave Repair)
by tjgx100 12/5/2008 2:04:52 PM(UTC)
Control Board replacement for a GE stove. (Oven Repair (including Ranges and Cooktops))
by fireman 8/26/2008 7:21:38 AM(UTC)
Control Board replacement instructions needed (Oven Repair (including Ranges and Cooktops))
by edsel58 7/17/2008 2:59:36 PM(UTC)
Kenmore Elite Control Board Replacement (Washer Repair)
by TAEHARVEY 1/6/2008 5:15:10 AM(UTC)
Maytag control board replacement (Refrigerator & Freezer Repair)
by catsun54 9/28/2007 9:23:40 AM(UTC)
2 Pages12>
