reddratt
#1 Posted : Tuesday, January 20, 2009 6:14:09 PM(UTC)
reddratt
wont heat anything after 2 1/2 min. loud hum stops when food stops heating. no codes.turntable spins.light is on.
#2 Posted : Wednesday, January 21, 2009 5:32:50 PM(UTC)
Are you able to restart it?
reddratt
#3 Posted : Thursday, January 22, 2009 7:13:24 PM(UTC)
reddratt
yes works fine as long as you dont use too long.no frozen vegies stops heating after 2 1/2 maybe 3 min at most. i heard a loud bang once right before this started to happen.
#4 Posted : Thursday, January 22, 2009 10:43:15 PM(UTC)
Does the display go off when it stops?
Check the cooling fan (#16 on the break down diagram).
reddratt
#5 Posted : Friday, January 23, 2009 7:25:26 PM(UTC)
reddratt
display stays on.i think thermal limit is shutting off the magnetron.is the cooling fan supposed to run all the time the microwave is working?
#6 Posted : Saturday, January 24, 2009 3:56:59 PM(UTC)
The cooling fan suppose to run wherever the magnetron runs. If it does not then the magnetron will overheat and the TCO will shut the power to the high voltage transformer off. That's probably what happened with your microwave.
reddratt
#7 Posted : Sunday, January 25, 2009 6:32:51 PM(UTC)
reddratt
how does the cooling fan motor come out? does the bottom unscrew off cabinet?
#8 Posted : Monday, January 26, 2009 1:23:20 PM(UTC)
You probably have to remove the microwave from the cabinet and remove the outer case.
Guest (6)
Samsung dv220agw - heating problem (Dryer Repair)
by jjandrews222 3/8/2021 6:18:21 PM(UTC)
Electric Admiral Dryer heating problems. (Dryer Repair)
by ShaneBurle24 7/12/2018 8:32:23 AM(UTC)
Whirlpool Gas Dryer Heating Problem (Dryer Repair)
by rinkugaya 9/24/2016 3:17:35 PM(UTC)
Dryer heating problem (Dryer Repair)
by Doehr 8/28/2016 10:41:56 AM(UTC)
Oven Heating Problem (Oven Repair (including Ranges and Cooktops))
by Jman1 1/20/2016 4:33:59 PM(UTC)
Roper dryer heating problems (Dryer Repair)
by laurencp72 1/19/2016 4:58:28 PM(UTC)
Kenmore Elite HE3 gas heating problems (Dryer Repair)
by karl1970 12/24/2014 6:39:08 PM(UTC)
Intermittent heating problem with gas dryer (Dryer Repair)
by David L. Mandel 8/16/2014 8:21:23 PM(UTC)
Diagnosing Heating Problem (Dishwasher Repair)
by glmoore0001 2/18/2014 10:16:59 AM(UTC)
oven heating problem (Oven Repair (including Ranges and Cooktops))
by 9point1 11/20/2013 9:30:19 AM(UTC)
LG LSE3092ST Oven Heating Problem (Oven Repair (including Ranges and Cooktops))
by parabola 10/8/2013 8:51:33 AM(UTC)
maytag stacked Dryer heating problem. (Dryer Repair)
by yudule 8/13/2013 10:30:40 AM(UTC)
by HOLLYTIM 6/11/2013 5:41:18 AM(UTC)
Need more help with dryer heating problems (Dryer Repair)
by Steves9411 4/12/2013 4:53:45 AM(UTC)
Heating Problem Issues (Dryer Repair)
by dmikel12 10/8/2012 4:01:27 PM(UTC)
