mcallitsis
#1 Posted : Tuesday, January 20, 2009 5:20:34 PM(UTC)
mcallitsis
I recently replaced the detergent assembly and in doing so ripped the front panel electrical source off when the door fell apart. Do I have to buy a whole new front panel or can I just replace the electrical source that ripped off the mother board?
#2 Posted : Wednesday, January 21, 2009 1:09:18 AM(UTC)
Here is a parts breakdown
Model Search
Could you please explain it a little better.
There are a number of plugs going to the control board.
Which one ripped off?
Is the plug damaged?
Is the control board damaged?
mcallitsis
#3 Posted : Wednesday, January 21, 2009 3:09:48 PM(UTC)
mcallitsis
part 901 for this model the strip of tape on the back of this part ripped in half. It is electrical and attaches to motherboard. I can't explain it much better because I don't know the exact part name.
#4 Posted : Wednesday, January 21, 2009 6:18:54 PM(UTC)
Just to confirm what ripped in half.
It is the cable that is sticking out on the right hand side of the Part 901 diagram.
It is a ribbon cable.
To get it you have to buy the complete part 901 (Keypad)
It is hard wired to the keypad.
If you have a friend who is into electronics they may be able to fix it.
Taking it to a shop would probably cost you as much as a new keypad.
mcallitsis
#5 Posted : Thursday, January 22, 2009 9:21:12 AM(UTC)
mcallitsis
Thank you thats what I needed to know. Will I be able to attach the other end of the ribbon cable from the keypad to the other part or do I just need to go ahead and call a repairman?
#6 Posted : Thursday, January 22, 2009 10:56:38 AM(UTC)
Take a look at the parts breakdown Section1.
#901 Keypad's ribbon cable plugs into #905 Module Control. Click on the pictures for a better view and you can clearly see where it plugs in.
Whether to get a tech or not depends upon your comfort level.
I definitely would do it but I have always enjoyed taking things apart and putting them back together (most of the time).
You got it apart you should be able to get it back together, just take your time
#7 Posted : Thursday, January 22, 2009 11:03:55 AM(UTC)
Duplicated the last one
GE Triton XL (Dishwasher Repair)
by engrguy 7/5/2017 7:06:55 AM(UTC)
GE Triton XL not fully draining (Dishwasher Repair)
by Frank58 5/12/2015 4:30:10 AM(UTC)
GE Triton XL - Stuck on rinse cycle, drain pump runs constantly (Dishwasher Repair)
by str-il 5/16/2013 4:02:50 PM(UTC)
old GE Triton XL: easy to replace heating element?? (Dishwasher Repair)
by Paul_illinois 12/28/2012 10:06:53 AM(UTC)
GE TRITON XL water starts into machine but never washes (Dishwasher Repair)
by NC dishwasherprob 2/24/2012 10:13:20 AM(UTC)
GE Triton XL Middle Spray Arm missing O-ring (Dishwasher Repair)
by Johan Stayple 5/11/2011 10:23:26 PM(UTC)
GE Triton XL water inlet valve trips breaker (Dishwasher Repair)
Belarus ryanbdkane 3/10/2011 7:22:30 PM(UTC)
GE Triton XL Dishwasher (Dishwasher Repair)
by Randye 2/23/2011 7:54:44 AM(UTC)
GE Triton XL will not drain (Dishwasher Repair)
by SisQ 2/22/2011 5:03:40 PM(UTC)
GE Triton XL Bottom Seal Replacement (Dishwasher Repair)
by kameltarazi 1/23/2011 11:29:13 AM(UTC)
replacing soap dispenser for GE triton XL (Dishwasher Repair)
by tuabui 5/24/2010 6:46:36 AM(UTC)
GE Triton XL Leaking from Front Right (Dishwasher Repair)
by jlewin 2/21/2010 6:50:23 AM(UTC)
GE Triton XL dishwasher not draining water completely (Dishwasher Repair)
by ajain99 1/12/2010 11:49:37 AM(UTC)
GE Triton XL leaves top rack dishes/glasses dirty (Dishwasher Repair)
by dsovetsky 10/15/2009 9:03:07 AM(UTC)
GE Triton XL will not pump water in (Dishwasher Repair)
by xfeejayx 8/1/2009 9:16:14 AM(UTC)
