mjm0927
#1 Posted : Friday, November 4, 2011 9:53:41 AM(UTC)
mjm0927
I have an old Whirlpool oven model sf365bep. I noticed the other day the oven was not getting hot, but the broiler and the burners worked. Then yeaterday the oven does not light at all, the broiler wil light but goes out after a few minutes.
Gary/APP Team
#2 Posted : Friday, November 4, 2011 10:26:44 AM(UTC)
mattt
Hello MJM0927. It seems like your Part number: ap4273180
is going bad. I would also check the Part number: ap2934763
to make sure its heating up properly so that it will ignite the gas. You should be able to visually do this Thank You and Good Luck !
#3 Posted : Friday, November 4, 2011 12:09:47 PM(UTC)
Just to add my 2 cents...
If the Bake igniter does glow but the gas does not flow through the burner, then most likely the problem is a bad (weak) igniter. The following article on our forum will explain in detail How Oven Igniter Works.
If you would like to check the igniter before you'll order a new one, you can do it by measuring the current drawn by the igniter. If the reading is 3.2 amps or less - the igniter has to be replaced.
New igniter comes without mounting bracket, so you have to use the old bracket.
If the Bake igniter does not glow while the control calls for Bake, then more tests have to be done. Post the results and we will guide you further.
P.S. The model number you posted is incomplete. In case if further assistance needed, verify and repost the model number.
Guest (4)
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
by Guest 12/15/2022 6:58:50 AM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Bottom oven not heating (Oven Repair (including Ranges and Cooktops))
by Castelle 1/21/2022 6:17:26 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
Frigidaire GLEF378CBD - oven not heating (Oven Repair (including Ranges and Cooktops))
by canooten 3/20/2020 11:24:19 AM(UTC)
by deanowhitney 7/11/2018 11:22:38 AM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
Oven not heating when using convection (Oven Repair (including Ranges and Cooktops))
by ebonyclose 3/11/2018 7:37:25 PM(UTC)
Frigidaire Double Oven - Lower Oven not heating - Clicking (Oven Repair (including Ranges and Cooktops))
by RentAHubby 10/3/2017 8:42:44 PM(UTC)
Whirlpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by proto8432 7/15/2017 10:07:03 AM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
Upper oven not heating, lower over works properly (Oven Repair (including Ranges and Cooktops))
by Greg2cycle 11/5/2016 9:50:34 AM(UTC)
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9/14/2016 6:24:38 AM(UTC)
Whirpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by cdfrerichs01 8/7/2016 10:55:06 AM(UTC)
